Old 08-12-2016, 04:42 PM   #1
ablarson's Avatar
Hooking up to cable at RV Park
Hey all. This is my first time hooking up to cable at an RV park (Trying to watch pre-season game) and it's not working.
I bought a cable from the camp store. Hooked it up to cable input in the sewer bay and ran other end to cable hookup on power pole.
Pushed little button on wall plate behind TV in overhead bunk area so green light turned off.
Changed tv from air to cable and ran auto scan.
I checked to make sure cable was hooked up behind tv and powered off for 5 minutes then tried again. Nada
What am I doing wrong?
Thanks in advance for any advice.
Newbie
19 States
2016 Dynamax Force HD
ablarson is offline   Reply With Quote
Old 08-12-2016, 05:25 PM   #2
ablarson's Avatar
Never mind, I got it. Was a bad cable.
Newbie
19 States
Old 08-12-2016, 05:28 PM   #3
Some cable companies require a cable box, descrambler. The last campground I stayed at in Altoona, PA offered boxes for free, just had to put a deposit on the box. Check with the campground office to determine if a box is required at your location.
cgotto1204 is offline   Reply With Quote
Old 08-13-2016, 07:30 PM   #4
halla's Avatar
Bad cables are common. My connection in the sewer bay was bad, had to put a new one in.
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 08-13-2016, 08:23 PM   #5
john5646's Avatar
Note. Buster should not be used when using park cable. It will distort reception.
Only used for antenna reception. Click image for larger version
Name:	ImageUploadedByForest River Forums1471137804.355059.jpg
john5646 is offline   Reply With Quote
Old 08-14-2016, 07:09 AM   #6
Mr. Dan's Avatar
OP said his booster was OFF... said he found his problem - a bad cable. No further investigation is needed.
Mr. Dan is offline   Reply With Quote
cable
