If you want to heat your water by L.P., YOU turn that switch on, other then that your w/h is set to electric
If you want it to recover faster leave it set for electric and turn on the L.P.. That little light next to it will light until the burner starts the first x only, then when the gas comes on and you didn't shut it off you won't see the little red light again, hope that helps, your on off electrical switch is on the face of the heater itself behind the gas line on the bottom left.
Coachmen M/H
Concord
2018 / 300 DSC
