Old 03-16-2018, 11:19 PM   #1
How to secure a pocket door
We took our new 36FK out to the Grand Canyon for its inaugural trip. Most everything worked fine and those that didn't are currently being repaired at the dealership.
One thing that didn't work so well was the pocket door between the washer/dryer and the bathroom. The bungee cord security system failed when the wife attempted to use that door. One end of the cord separated from the plastic retainer leaving a length of cord rather than the bight. Two attempts to fix it resulted in it just pulling out again and again. On the other hand, the sliding door between the bedroom and the bathroom/sink area worked flawlessly. That door utilizes a rare earth magnet to retain the door. Since neither of these doors will be used very often (maybe once or twice a year) I would rather have the door securely fastened during transits rather than easily released to close.
So, I am looking to replace the bungee capture system with the rare earth magnet. My question is has anyone else attempted this? Is the magnet(s) part available from Dynamax (Brian?)?
Thanks!
Joe
2018 DX3 36FK
2013 Jeep JKU
Happyatrest is offline   Reply With Quote
Old 03-17-2018, 12:27 AM   #2
halla's Avatar
I like the magnet on the front door as stated, but I am not sure how you would install the magnet on the other door, not enough room between the bathroom and the washer/dryer. I will probably install another stainless steel bolt lock on the bottom of the door like I had on the Force. Kept the door in place when traveling, no issues.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 03-17-2018, 09:57 AM   #3
I use the stainless locks that Halla refers to, they work great.
Jammer151 is offline   Reply With Quote
Old 03-17-2018, 07:10 PM   #4
CSWVK's Avatar
We use the SS bolts on both our sliders. The banging while traveling was very distracting. They work really well and are a simple solution.
Cindy & Walt
2018 DX3 36FK
CSWVK is offline   Reply With Quote
Old 03-18-2018, 03:30 PM   #5
Our pocket doors have a white plastic strap that runs across the front and snaps to the other wall.
Portagie1968 is offline   Reply With Quote
Old 03-18-2018, 05:32 PM   #6
DouglasReid's Avatar
Our previous camper had a pocket door. Its strap went from one side to a snap on the front of the door edge itself. When it was snapped it never came loose while traveling. Unsnap it and the strap hung on the side of the wall.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-18-2018, 07:38 PM   #7
One of our straps helps us meet one of the owners of the Premier RV Resorts. Forest River did not install, nothing new on our wicked kitty, it correctly and it broke. We met the owner at Boardman, Or and with his selection of washers and screws we were able to fix both door straps correctly. Another of the many fixes that Forest River installed incorrectly.
Old 03-18-2018, 08:02 PM   #8
Cyber Phrenologist
Radio's Avatar
On my 5ver we use a piece of pool noodle. You can't leave it in there forever or it looses it's "springiness" use it only when traveling. We use a longer piece in the microwave between the turntable and the top inside of the oven to hold the turntable in place.
We put it there because the constant movement of the door pulls the little strap apart over time. Having fixed it 3 times I came up with this.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 03-18-2018, 08:08 PM   #9
halla's Avatar
one thousand uses for pool noodles.
Old 03-18-2018, 08:25 PM   #10
Cyber Phrenologist
Radio's Avatar
I started a thread "100 used for a 5 gallon bucket." but the forum could only come up with 34.
But I bet we could find 1000 uses for pool noodles.
KU4OJ
door
