i'm glad you now have power! i learned something as i had not seen the dual 30 amp connection adapter before. depending upon your configuration and usage there is one other adapter you might consider. that is one that has a normal 15 amp male plug on one side and a rv 30 amp female receptacle on the other. with this you can plug it into an extension cord, plug your new 30 to 50 adapter in, and then your 50 amp shore power cord. we have used this configuration to keep a residential refrigerator running while we had the trailer in storage. just depends on what you see yourself doing.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
