Old 08-15-2019, 05:08 PM   #1
Worm43's Avatar
Inside Ceiling Outside Cap
My inside ceiling is separating from the seam daily. I have to press it under the seam strip. While driving the cap seems to be creaking loudly. Getting worse daily. Any solution for the inside seam or separation of the outside cap if it occurs?
This is a 2017 Dynaquest
Worm43 is offline   Reply With Quote
Old 08-15-2019, 09:24 PM   #2
Commercial Member
1. depends on what you mean. Its soft touch foam, laminate to lauan. So it could be the vinyl shrinking coming out or its the panel. Picture would help
2. Depending if you have a cab over or non cab over...I assume being an XL it is the non-cabover since we didnt start that until later (I think). So it might just need a wider seam strip.
3. inside seam separation does not mean outside cap separation. Outside cap, mounts and fastens differently than the inside portion.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 08-16-2019, 02:26 AM   #3
Worm43's Avatar
Can I order a wider seam strip from Dynamax parts?
Old 08-16-2019, 07:33 AM   #4
Commercial Member
In theory, but without a picture, I couldn't tell you what to order or if it is needed.
Old 08-18-2019, 01:42 PM   #5
Worm43's Avatar
This was after 300 mile ride .Hope picture shows up
Old 08-19-2019, 03:53 PM   #6
Commercial Member
That is a vinyl wrapped T-molding. It actually snaps into a track.
We don't carry anything larger than 1" (which is shown), but they do make 1.5" versions in white.
You might be table to take the trim off and maybe tape ti down into place, then snap it back on. I have some white electrical tape would would add just enough length to keep it under wraps and not really stick out.
