Originally Posted by Fizzypoo
We have newly acquired a 2006 Dynamax Isata 282. We have a 1000W inverter that is not giving DC power to the outlets. It appears to be charging the batteries, and the status light is on, but no power to the outlets when we are not plugged in to electric. Is there a fuse somewhere that may be tripped and if so, where would this fuse be? Any help in this would be great. Thanks.
Bonnie Harris
Generators
Conventional generators have a motor attached to an alternator that produces electricity. The motor must run at a constant speed usually, 3600 rpm to produce the standard frequency of 60 cycle current. If the engine’s rpm fluctuates, so will the frequency of electric output.
Converters
Converters are powered by 120 v AC current and changes it to 12 v DC current. No motor involved. Except cooling fan.
Inverters
A traditional inverter is powered by a 12 volt battery and produces 120v AC at limited wattage. No motor involved. Commonly used in Motor homes and high-end 5th wheels. .
Inverter Generators
These are motor driven 3-phase generators that output AC current like most traditional generators, but that current is then converted to DC, and then “inverted” back to clean AC power and frequency
They are called “inverter generators” but since people tend to simplify terminology, “inverter generator” often gets changed, sometimes to “inverter” and sometimes to “generator” which leads to confusion as which one is being discussed. Both terms are commonly used to refer to inverter generators.
