Originally Posted by brewnut44
Bob,
Thank you for this input. We were actually looking at the CRV as well, also assumed 45mhp uphills sounds right. The 4200 tow limit is first heard as all the dealers talk 5k. If I may ask a couple other questions: does it feel like your pulling a heavy load or does it pull it rather smoothly? how does it brake going down hill as I see no tow/haul mode or exhaust brake capibilties? I assume you can down shift but will this slow a pretty good hold back?
We just did the Ca parks last spring and I will say the Sierra foot hills are the toughest hills I ever delt with in terms of down hill and retention of speed then right back up and stop lights at the tops and bottom. We do pull a 5th wheel with a duramax and it has all the buttons but man it was a ride at times to keep under 45.
Sorry I didn't get back to you sooner. If you decide on a CRV you need to find a 2014 or older one. In 2015 they began using a CVT transmission and you cannot tow it with all 4 wheels on the ground although you could use a dolly (more weight). It does tow nicely though. I notice the acceleration and mileage are less but on the interstates I hardly know it's back there.
I do downshift as necessary in the mountains. Something I have done my entire life to save the brakes. (I now have 38,000 miles and 12,000 towing miles on the original brakes of the CRV. My mechanic said they were about half worn out at the last oil change.) I added a braking system so it stops reasonably well although I always try to maintain a good distance for stopping.
Hope this helps you with your decision.
Bob Fraser
2017 Forester 2401W
