Originally Posted by Barch
Good suggestions. Thank you all. The best solution would be to put the bedroom outlets on the inverter circuit and/or have a 12 volt outlet. CPAP machines can run off either. There are hundreds of thousands of people (baby boomers) using CPAP. Other RV manufacturers actually advertise that there bedrooms have outlets for CPAP. The extension cord from the TV outlet or modifying the bedside 12 volt outlet are good workarounds. I will inquire when I place my order if the bedroom outlets can be connected to the inverter.
My DW had the door pulled out of her hand when exiting our Forester 2401W in a high wind. The strut anchor pulled out of the door never to be seen again and leaving an enlarged hole in the door where it was attached. I too have been pondering a repair and solution to the problem.
My first thought is to re-attach or replace the strut to permit the door to fully open and stop just before hitting the retracted awning arm. This solution would also need a bumper installed on the arm where the door would hit when the awning is extended.
Second thought is to install a second strut at the top of the door to distribute the impact when the wind grabs the door. I have seen storm doors with this araingement.
Third thought is to install a strong thin rope at the top of the door to limit the amount it can open.
Since my motor home is in storage 30 m
