Old 05-21-2017, 06:44 PM   #1
Isata 3 Owners
Hi,
We are about two weeks out from our 2018 Isata 3 24FW being completed, at which time we need to pick up in Michigan. My question for you owners is what is the rear hitch height? Soon we are going to set up our tow vehicle and this height would help a bunch. Appreciate your help. Thanks.
Mike
mdth is offline   Reply With Quote
Old 05-22-2017, 07:42 AM   #2
Commercial Member
Its a 5000lb hitch, but just realize your actual towing is based on a few other factors.
Your gross combined weight rating minus your gross vehicle weight rating gives you the total amount you can tow 4 wheels down. Which on the Sprinter is 4200 lbs. If you tow a trailer...then you have to factor in tongue weight and that gets subtracted from the GVWR.
Easiest way is to tow 4 wheels on the ground, then its simple.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 05-22-2017, 07:57 AM   #3
Thanks Brian, four down is what we are going to do, all should be good. The hitch height would really help in getting our toad set up. Thanks
Old 05-22-2017, 10:11 AM   #4
chroniekon's Avatar
Mine measures 18" from the ground up to the bottom of the 2" square hole in the receiver.
chroniekon is offline   Reply With Quote
Old 05-22-2017, 10:21 AM   #5
Thank you, that is what I needed to know.
Mike
