05-05-2017, 04:23 PM
#301
Commercial Member
Sorry to say, they are not the same machine. Same floor plan, but our construction is different from theirs. Their roof is laminated block foam...so the main structure is a perimeter frame of aluminum. The core, is large crowned/domed blocks of foam that run wall to wall and the duct work is molded in. That is topped with lauan board and fiberglass and all glued together.
Our roof is more traditional construction. Aluminum rafters 16" OC. Foil face duct work is routed through the truss openings, batt insulation is laid on top of that. Then 1/4" rigid core decking and one piece fiberglass that rolls over the edges.
So my main concern would be the skylight and how big it might be. Their roof is mainly block foam with some support structure put in where they want the skylight. If that skylight is design to fit between 16" OC trusts, then you are fine as long as you locate it in the correct spot.
05-05-2017, 07:25 PM
#302
I ordered the parts from Forest River for the MBS, I'll have to measure it but I think it should fit fine between the 16" struts (what does "OC" mean? On center?).
Thanks for the feedback, I'll make sure they are very careful with where they place it and to make sure any ductwork is rerouted. I plan on putting it in the same place it is in the MBS, which is basically behind the driver's seat...
05-15-2017, 11:08 AM
#303
Originally Posted by chroniekon
I need a part too. It seems I have a drivers side armrest mechanism on the passenger side seat. It works backwards. When I take it off and put it on the drivers side, it works perfectly. I made a short video that shows clearly what is going on, but I couldn't get it to install here on the forum, I can send it email if you want.
Originally Posted by bclemens
Got it and we've already been in contact with Mercedes.
Brian, Have there been any updates on this part?
05-15-2017, 11:14 AM
#304
Commercial Member
Not at this time. It is still on order...but an odd part like this will more than likely come from Germany. Which will take some time.
05-15-2017, 11:25 AM
#305
06-02-2017, 03:04 PM
#306
Does anyone have a link to a formal source for the CCC definition?
This one appears to be wrong. http://www.fulltime-rving.com/Cargo_..._Capacity.html
Alternately, how can I find the UVW for a particular vehicle and run through the numbers myself?
Another question is about propane. We know that we can only fill tanks to 80% of their capacity. Is 20.3 gallons the gross or net capacity?
As you might guess, loading is a challenge which is making a final purchase decision difficult for me.
06-02-2017, 03:13 PM
#307
Commercial Member
UVW is the motorhome as it sits with FULL FUELS only. So the chassis has a all necessary fluids including full tank. The coach portion is full propane tank. That is UVW. CCC is GVWR minus UVW. CCC is what you have left for fresh water, cargo and occupants.
Propane tank is typically listed as (WC) or Water Capacity. In our 2018 Isata 3 brochure, under Utilities, we list this as 20.3 LP tank (WC). What it can actually hold is 80% of that. Most mfg's list the WC, but not all of them call it out as such.
PS. You will typically not see UVW listed anywhere because each coach is weighed now and a sticker place on the door. We no longer estimate or average the numbers....so once you publish a UVW as a guess, it will be wrong based on options selected.
06-02-2017, 03:20 PM
#308
Commercial Member
I made up a spread sheet a while back so that you didn't forget about tongue weight. Nothing complicated once you know a trailer typically puts 10% of its weight onto the tongue (which goes against CCC). But if you tow 4 wheels down, you can load stuff into the tow vehicle to save on motorhome CCC.
Water is 8.34 per gallon.
We figure all of our fuel at 7lbs.
06-02-2017, 03:42 PM
#309
Thank you very much. There is a lot of dubious information out there so it is good to hear it from the source. The biggest one is that a 154 lb / 70kg driver is included in the UVW.
The coach that I am looking at shows a CCC of 784 lbs. A full load of water weighing 290 lbs. The coach that we are looking at has a tankless water heater which accounts for the 6 gallon difference to your spreadsheet.
As long as we don't tanker a lot of water between stops (we tend to dry camp in Provincial Parks in British Columbia with water available at the entrance for shorter trips or have full hookups on longer trips), we should just about be able to manage.
1/4 water on the road plus 330 lbs for me and the wife leaves about 380 lbs for "stuff" with full fuel and full propane.
We are really hoping to avoid towing.
06-02-2017, 03:46 PM
#310
Another place where the explanation is wrong.
How Cargo Carrying Capacity (CCC) Works | HowStuffWorks
Edit to add : Actually, I think that there are pre and post 2009 rules. The links that I mentioned are the pre 2009 rules.
06-02-2017, 04:05 PM
#311
Here is a picture of my actual weight sticker from the drivers door frame. It explains how the numbers were calculated. Since I never carry fresh water, I added the two weights together and got 428 kg or 943 lbs.
06-02-2017, 04:10 PM
#312
Commercial Member
A lot of the data out there is based on the old system...which is why it got changed.
One mfg would list their CCC in BIG BOLD NUMBERS. and then in tiny print below say "for 1 person subtract 154, for two people 308, fresh water, XXX". you get the point. And then other mfg's would play by the rules and list CCC as "GVWR-UVW-(154 lbs times each seatbelt position)-full fresh water"
So one MFG would have this HUGE CCC number even though their actual CCC was less than the guy that listed it properly and showed a smaller number.
06-02-2017, 04:11 PM
#313
Commercial Member
The Canadian weight sticker factors full fresh water, the US version does not.
06-02-2017, 04:35 PM
#314
The one that I am in negotiations about is a Canadian vehicle with a dealer in British Columbia.
The sticker simply says that the combined weight of occupant and cargo should never exceed 536 kg or 784 lbs. It then cautions that a full load of water equals 132 kg or 290 lbs of cargo @ 1kg/L (8.3 lb/gal) and that the tongue weight of a towed trailer counts as cargo. The statement is a bit ambiguous. It could be read to mean that water is in additional cargo or that leaving out the water gives us more room for cargo.
It is a new 2017 coach with auto levelling jacks. It has the steel sink in the bathroom and the new shower door and the tankless hot water heater. Based on what I have read here and my initial understanding of the sticker, it seems more likely that I can load 784 lbs of driver, passenger and "stuff" with no water than 784 + 290 = 1,074 lbs.
I have not looked at a US vehicle. Is a touch above 1,000 lbs in CCC for new coaches with auto levelling jacks and not much else within the range that you usually see for US vehicles.
300 lbs is a huge amount of extra capacity and turns a marginal decision into a no brainer.
06-02-2017, 04:43 PM
#315
Commercial Member
If that coach has leveling jacks...then I would guess that it is 784lbs of CCC for passengers, cargo and water. The way I read that is that they consider water to be cargo.
06-02-2017, 04:49 PM
#316
So the weight sticker on a Canadian vehicle does not include water which is contrary to what you said a bit earlier.
The options listing includes "FULL PAINT WITH DIAMOND SHIELD,AUTOMATIC, 4-POINT HYDRAULIC LEVELING JACKS,CANADIAN CHASSIS,Z240 CANADIAN CERTIFICATION FEE,CAB SEAT BOOSTER CUSHIONS,CANADIAN MVSA"
I have to admit to being a bit confused.
Edit to add : Looking at the applicable CFR, this is the US sticker and a bilingual Canadian sticker will be attached before delivery with a CCC of 494 lbs / 224 kg and water weighing 290 lbs or 132 kg. Bummer.
06-03-2017, 06:55 AM
#317
Wow and I was shocked how low our Forester MBS CCC was at 925 pounds.
You'll be able to carry paper plates, a bar of soap, a bathing suit and flip flops.
Those Alcoa aluminum wheels (x7) are looking better every day with removing about 100 pounds of weight from an already heavy coach.
I suspect most MBS owners actually run overweight much of the time...
06-03-2017, 08:09 AM
#318
Isn't that the definition of the new OCCC?
Dave & Julie - Motorhomeless for a while!
SOLD 2018 Isata-3 24FW - Invisibrake/Roadmaster Falcon All-Terrain Tow Bar/2019 Wrangler Sport S 2.0 Turbo
SOLD 2015 Tiffin Allegro 36LA/2014 Wrangler Sahara Unlimited
06-06-2017, 04:26 PM
#319
My cargo carrying capacity is equal to whatever I bring with me I don't bring a lot of stuff but we really don't notice any handling problems
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
06-06-2017, 04:38 PM
#320
2020 S.O.B.
