10-11-2017, 12:29 PM
#381
That’s why we bought also. Wife sold on that sofa. Question for B.C.
Can I buy that piece of hardware that connects table to post. I want to build a larger table so when kids come camping, we could bring a couple of chairs from outside in and all sit together at the table, maybe using the included boosters?
10-11-2017, 12:46 PM
#382
Commercial Member
Sure...its just a Springfield table mount. Dealer should be able to get it for you
10-11-2017, 04:51 PM
#383
Originally Posted by zgipson
We used a couple different styles of dinette in 2017 trying to find the one we liked... do you have a photo of what yours looks like?
Here is my dinette. The end caps are held on from the inside with two screws.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
10-12-2017, 06:29 PM
#384
Audio Visual
My 24FW that is on order will have the cabover bunk and in-motion satellite options and I wanted to know if the cabinet to the right of the coach door over the sink has a power outlet and an HDMI connection if you wanted to use a Blueray player versus the house DVD player.
Jhenrytri
10-14-2017, 09:01 PM
#385
RW tri-fold sofabed?
While the sofa has flip-up foot rests, I wouldn't necessarily say it reclines... We tried to find a sofa that had more creature comforts (the foot rests) and also doubled as a more functional bed with better comfort and ease of use over the pull out beds or air mattresses.
Forgive the terrible angle, tried to snap a shot of it with the slideout in.
Is this same sofa used in the RW. Is this a tri-fold with the footrests & TV trays?
10-16-2017, 07:59 AM
#386
Generator exhaust
It looks like the generator exhaust pipe end exits under the driver side rear and does not fully clear the full wall slide out. Wondering if anyone has had issue attaching a vertical exhaust pipe extension to the generator exhaust since it does not exit chassis beyond the rear extension of the slide out?
10-16-2017, 09:53 AM
#387
Curious: are you considering doing this for safety concerns or noise reduction?
10-16-2017, 11:33 AM
#388
Safety and courtesy. We dry camp on occasion at events where there is minimal spacing between RVs and vertical vent pipes are required to keep exhaust fumes away from vehicles and open windows.
10-29-2017, 10:06 AM
#389
Generator Exhaust Pipe
Brian,
I never got a response about where the generator exhaust pipe exits the undercarriage of the 24FW and whether it exits past the rear most extension of the full wall slide. We dry camp at events where a vertical vent pipe extension are required for operating the generator. We have a 24FW on order with the leveling jack option so I am wondering if the exhaust pipe can be routed farther to the rear of the vehicle since our unit will not have the stabilizing jacks.
Thank you,
Jhenrytri
10-29-2017, 10:10 AM
#390
You may want to private message him since time is an issue. Good luck.
2017 Isata 3 on a 2016 Sprinter
10-30-2017, 09:48 AM
#391
Commercial Member
Brian,
Thank you,
Jhenrytri
I'll try to fill in where I can, usually BC beats me to the punch on most thing and knows a heck of a lot more than I do! The exhaust for the genny does not clear the end of the slideout. The slideout takes up just about the entire wall so where the exhaust is located is a couple feet short of the end of the slide if that makes sense. Hopefully the picture helps. Kind of have to play with what we have in terms of where the genny is located on the coach.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
11-04-2017, 02:05 PM
#392
Can I use snow chains on this thing?
11-04-2017, 03:05 PM
#393
I bought a set for mine for our trip from Michigan to Oregon last March. Didn't have to use them, but don't see why they wouldn't work. Some states require you to carry them.
11-04-2017, 03:47 PM
#394
Chroniekon, what manufacturer/part number?
11-04-2017, 04:03 PM
#395
Campbell #003-1944. I got lucky and found a set on eBay.
11-04-2017, 04:26 PM
#396
Ebay has just about everything. Thanks.
11-05-2017, 10:41 AM
#397
Thanks you guys! It just looks like the grey piece is pretty close to the tire, but maybe it just needs to be that the chains need to be adjusted tightly.
Anyone know the tire size?
11-05-2017, 10:45 AM
#398
Originally Posted by gusinca
thanks you guys! It just looks like the grey piece is pretty close to the tire, but maybe it just needs to be that the chains need to be adjusted tightly.
lt215/85r/16
11-05-2017, 11:15 AM
#399
Thanks, just ordered the Super Z cable chains from Amazon. They look like they're snug fitting and low profile.
We're heading up to an RV resort in Tahoe for Christmas, so I want to be prepared.
11-05-2017, 12:20 PM
#400
This type of thing will help keep things tight.
https://www.amazon.com/Security-Chai...hain+tensioner
Also, I carry a piece of 2X8 to put under the inside dual. No need to jack the rig up, just drive up on the board. It's much easier to get things snugged up with the tire off the ground. And I've found it's a good idea to do a 'dry run' putting the chains on.
