Old 12-09-2017, 04:41 PM   #1
caswelld's Avatar
Isata 3 sewer hose?
So, the Camco Rhino hose doesn't fit on the Isata 3
What brand of sewer hose fits the coupler on the Isata 3 use?
Thanks,
Dave
Dave & Julie - Motorhomeless for a while!
SOLD 2018 Isata-3 24FW - Invisibrake/Roadmaster Falcon All-Terrain Tow Bar/2019 Wrangler Sport S 2.0 Turbo
SOLD 2015 Tiffin Allegro 36LA/2014 Wrangler Sahara Unlimited
caswelld is offline   Reply With Quote
Old 12-09-2017, 04:45 PM   #2
Sandiegodoug's Avatar
I use the eze coupler
It’s red
Sandiegodoug is offline   Reply With Quote
Old 12-09-2017, 08:19 PM   #3
I have a rhino hose and it fits fine, just doesn’t fit it the storage tube. Are you talking about hose storage?
Jlole76 is offline   Reply With Quote
Old 12-09-2017, 08:34 PM   #4
I fixed storage length by adding an elbow and a piece of drainage tube. Now a large size sewer hose fits in compartment
Old 12-10-2017, 10:39 AM   #5
caswelld's Avatar
Thanks Jlole76, I'll have to check it again.
I never had a connection issue with the Rhino on my other RVs. It looked like the bayonets fit snugly into the hose connector, but perhaps there was a way I miss-aligned it. It seemed that the Camco Rhino was about 1/16" bigger than the MH sewer pipe fitting. Fortunately I was dealing with gray water.
I'll check it again tomorrow.
Dave
Old 12-10-2017, 02:07 PM   #6
Rhino, but we added a clear section to the end of the original sewage pipe so we could see when it was running clear, also easier access
ACMN is offline   Reply With Quote
Old 12-10-2017, 02:24 PM   #7
I also added a twist on waste valve
Then the clear section to end. Have read stories of cable driven valves not shutting all the way and a mess coming out when take off cap.
Old 12-10-2017, 05:26 PM   #8
2020 Isata 5 30FW 4x4
Made one out of 6" thin wall PVC & some end caps. It's long enough that two Rhino hoses will fit inside so that expanded the hose could reach 20 feet. A 90 degree elbow also fits inside.
ID:	158045   Click image for larger version
ID:	158046   Click image for larger version
Spike4321 is offline   Reply With Quote
Old 12-10-2017, 10:14 PM   #9
caswelld's Avatar
Is the clear section at the motor home a 45 degree attachment?
Old 12-11-2017, 09:53 AM   #10
Ours straight approx a foot.long, the 45 degree makes sense although there isn't much length to it. Our rig is in storage or I would measure it, it comes out to the wall of the coach so no crawling around on the ground to attach hose to dump
Old 12-11-2017, 10:16 AM   #11
caswelld's Avatar
I just ordered this 7" extender from Amazon. That will get the end of the MH sewer pipe to within about 2" of the side wall.
I also ordered a set of new 'O' rings, maybe that will make the difference with the leak. It sure acted like it was a smaller sized sewer pipe on the MH.
Name:	camco sewer extension.jpg
