03-22-2018, 05:18 PM
Isata 3- why dinette seat belts?
Each dinette seat has a belt. The first thought would be that they are for the kids but since it doesn't seem to convert to a bed, where would they sleep?
Does anyone have any thoughts in that?
I should clarify that it's a 24FW if that makes a difference.
03-22-2018, 05:23 PM
For when driving with passengers in seat.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
It does turn into a bed.
03-22-2018, 05:37 PM
Well sure if you are using it for a town car.
03-22-2018, 05:38 PM
Please share how that's done.
03-22-2018, 05:47 PM
Remove the table. Remove the post. Set the table on the ledges on the seats.lay the back cushions on the table. Now it's a bed.
03-22-2018, 06:09 PM
Well that's what we assumed because our other two motorhomes have been like that. This one however, seems to have the wrap around backs permanently affixed.
Update: After jerking and tugging them a bit, they seem to have become unlatched from something. What is the trick to detaching them from the base or walls?
03-22-2018, 06:22 PM
Well that's what we assumed because our other two motorhomes have been like that. This one however, seems to have the wrap around backs permanently affixed. Attachment 165885
Sorry that's different than ours. Yours must not be set up to use as a bed.
03-22-2018, 08:28 PM
Commercial Member
You're missing the filler cushion. Those backs are fixed.
Commercial Member
Filler cushion normally ships loose in a cabinet. Sometimes dealers pull them out for some reason
03-23-2018, 10:29 AM
Are the filler cushions the same dimensions as the bottom cushions? I have the bottom cushions, I removed one for clarity.
Would the filler cushions be available from Dynamax? If so can I order direct? My dealer is rather unresponsive in such matters.
03-23-2018, 10:32 AM
Commercial Member
Same height...it is about the width of the table. You can try the direct parts email from our website....but I'm not sure they are doing parts direct anymore. If it was noted on the dealer check in sheet that it was missing it would be warrantable...which is why it would be best to go through your selling dealer.
03-23-2018, 10:37 AM
Thanks but It was preowned.
That's pretty large, where could it be stored?
03-23-2018, 10:43 AM
Commercial Member
therein lies the question. It was hinged so that it could be stored in the bed storage. or below the dinette.
03-23-2018, 10:53 AM
Ah, that make sense. It also explains why there are seat belts there.
Thanks for the answers.
03-23-2018, 12:05 PM
I have a one word answer:
LAWYERS!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-23-2018, 01:35 PM
Denver, CO
LAWYERS!
Lawyers put the seat belts in? I didn't think they were that handy.
2017 Fuse 23T
03-23-2018, 04:19 PM
Dinette Bed
With the slide out there is a long storage compartment under the mattress. That is where I keep my folding bed pad for the dinette. Pretty comfortable although just a little short for me.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
03-23-2018, 04:39 PM
It turns out that mine parted ways with the coach before I got it. At least my initial question got answered.
03-23-2018, 07:39 PM
X2. My wife and daughter both like to sit at dinette while traveling. Often using laptops to keep up with their jobs.
2017 Dynamax REV 24RB
2018 Ford F-150
