Originally Posted by cooper16
but I'm not comfortable with having just one roller supporting the platform.
Please note.....its not "just" one roller supporting the slide.
Please remember...there are rollers under the slide every 18" or so...maybe its 36" on the OUTBOARD side of the slide. That is what the slide mfg requires.
WE add inboard rollers, just to keep the slide from tipping. Our slides are way deeper than most (18-20" vs. 30-36"). So they are there, simply to support the edge, not support the weight of the slide.
Same goes for the outside...I know some people get concerned that the outside rollers are not touching...but in many cases it is because the inside roller or bed deck is doing all the work. If you shim the outside rollers...in many cases you can then put the whole thing in a bind.
