Originally Posted by maifimd
I'm curious to see if the pink stuff will back-fill the supply line from the exterior input if the check valve is operated.
OK, the supply input via Andersen valve through the undersink filter to the winterizing selector valve don't see the "pink stuff'. I had removed and drained the filter housing and added an empty water bottle prior to shifting to the winterize valve position at the water pump infeed. All the usual water points and the low point drains were 'pink', but nothing gets to the filter housing. I exercised the exterior water input check valve and got a trickle of water.
Should I be worried about the Andersen valve and water line to the pump?
Mike
