07-22-2018, 08:12 AM
Isata 5 Fresh Water, When is it filtered?
It appears, from this fresh water plumbing diagram, that the only time the fresh water runs through the filter (the one that is in the fresh water tank bay) is when it is pumped from the on-board (electric) pump. If you are hooked up to an outside water source through the inlet in the valve box (the one in the wet bay), it's simply plumbed to the coach and does not go through the filter.
Is that correct? Just want to make sure I am reading the drawing correctly.
2019 Dynamax Isata 5 35DB
Audi "Nardo Grey"
07-22-2018, 10:51 AM
I think you are right. I use one of those inline water filters you can buy at Walmart, that way you are doing some filtering of the RV Parks water. I don't drink it just wash and cook with it. I change the filter about once a month or so.
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
07-23-2018, 11:40 PM
Good to know. As a relative newbie to this motorhome stuff, I simply saw a water filter next to the fresh water tank and thought "hey great, this coach is filtered. I guess I don't need one of those in-line thingies that I see people using". That'll teach my to open my mouth.....or my inner monologue.
Audi "Nardo Grey"
07-24-2018, 09:54 AM
Why do you run straight from the hose and not use the tank? I’ve never used straight from the shore water (boat)! I don’t want “ stale” water in my tank. If I always fill the tank and use the onboard filter system l am always running fresh clorinated water thru the tank and keeping it relatively decontaminated.
2019 Dx3 TS
2020 RAM 1500 Limited Diesel 4x4
7 lb Guard Dog
Working hard on “elderhood”
07-24-2018, 10:20 AM
In an RV Park I use shore water. While driving I carry about half a tank for flushing and washing needs. If I’m planning on dry camping I fill up the tank. After every trip I empty the tank. I use an in-line hose connect filter for shore water. I never drink any of it. I drink bottled and use bottled for coffee.
07-24-2018, 11:55 AM
THAT is a really great question! I don’t know why I would or would not use the tank/electric pump vs. the shore supplied water source. I have done very little actual camping with an RV, so this is pretty new to me. At this point, I am just trying to teach myself the systems, how they work and why they work the way they do.
When you have a water hook-up at your camp site, is it “typical” to run from your tank and fill as needed? ….or to put it a better way, is that the “desirable” method?
Audi "Nardo Grey"
07-24-2018, 01:28 PM
When you use the tank, you have 'pump' noised and pump pressure. When you have shore water available, you have unlimited water at 50 psi (if you use a regulator and you must) and you have no pump noise. Save you tank water for when you are not hooked up, on the road.
Shore water at an RV park is just a hose away. I just don't drink it.
Old Navy Chief
07-24-2018, 02:09 PM
Commercial Member
As a word of caution...if you don't use a pressure regulator...your Truma will certainly tell you if the pressure is too high. Either that, or it is a "white noise" generator of water sounds.
07-24-2018, 02:58 PM
I installed an under sink filter hooked up to cold side of galley faucet. We only use the filtered water for drinking, coffee, etc. when hooked up to city water.
When dry camping we use bottled water for drinking and coffee.
I notice many campers with outside filters. I wonder why you would filter water that is used to shower and flush toilet.
07-24-2018, 03:24 PM
That's not a bad idea. I like it!
Audi "Nardo Grey"
07-24-2018, 03:25 PM
At what pressure do we receive this white noise?
Audi "Nardo Grey"
07-24-2018, 05:18 PM
With the typical hose mounted RV pressure regulator (50 lbs) you won't hear it.
Old Navy Chief
07-24-2018, 08:31 PM
.....I notice many campers with outside filters. I wonder why you would filter water that is used to shower and flush toilet.
Ice maker comes to mind
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
07-25-2018, 07:23 AM
Good thread. Hadn’t thought about this. Thanks.
Pat
2017 Isata 5
