Old 09-08-2016, 06:18 PM   #1
Isata 5 Lighting Question
Anyone know where the switch is, or how to turn on the LED lights over the master bed? They are located/installed in the bottom of the cabinets, and I can't find a switch to turn them on/off anywhere. The bedroom light switch does not turn them on or off either.
Stroker09 is offline   Reply With Quote
Old 09-08-2016, 07:34 PM   #2
Rrzasa's Avatar
There is a second set of switches on the wall on the left, one of the switches is for master lights, if you press it once I think the main lights come on, if you press it a second time, the lights over the head of the bed come on and if you press it again, the main bedroom lights go off and the under cabinet lights stay on. I believe that is the sequence in ours.
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Go Gators
Rrzasa is offline   Reply With Quote
Old 09-08-2016, 07:37 PM   #3
I will give that a try. Thanks a bunch.
Old 09-09-2016, 08:16 AM   #4
Commercial Member
zgipson's Avatar
You're spot on. With that Multiplex system in the Isata 5, some of the lights are turned on by hitting the button a few time to essentially "scroll" through the different ones. This is the case with the awning and patio lights. One click is for the patio light, two clicks for the patio and awning lights, three clicks for just the awning and four clicks to turn it all back off again.
It may sound like a hassle but it really handy when you get to use to it and really doesn't take that much time. It also requires one less button on the control panel, saving space.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
zgipson is offline   Reply With Quote
Old 09-20-2016, 02:11 PM   #5
Well, that didn't seem to work so I'll have to investigate whether or not the lights are actually wired or not. Ugh!!!
Old 09-20-2016, 03:50 PM   #6
Commercial Member
zgipson's Avatar
There is a little silver button on the light cover itself. Click that and they should come on!
Old 09-28-2016, 07:27 PM   #7
I do not see any "little silver button" on any of the LED light fixtures. I guess I need to check and see if there's a bad fuse or something.
Old 09-28-2016, 08:33 PM   #8
GM
bclemens's Avatar
The little silver button on the light itself was a later change...so you can control each light individually.
Otherwise, as they said...on the bedroom switch, press once for lights A, press again for lights B and press a 3rd time for light scenario C. If that still doesn't work, we might need to trouble shoot a circuit.
Old 11-14-2016, 06:38 PM   #9
Still haven't figured out this issue. No combination of operating the two switches in the bedroom will turn on the reading lights over the bed. There is no switch on the LED lights themselves. Don't want to travel 350+ miles to the dealer. Any chance of getting a wiring diagram for trouble shooting?
Old 11-15-2016, 10:08 AM   #10
GM
bclemens's Avatar
I'll take a look.
light
