Old 10-04-2016, 08:37 PM   #21
Note: there is a Force and a Force HD. I believe the Force is beyond 3,500 lbs, but that needs to be verified. The Force HD and DX3 I believe is up into the 8,000 to 9,000 lb plus range, again to be verified by some specific unit numbers.
Today I looked at a Ram 2500 4x4 crew cab that had a cargo and passenger rating of 2,116 pounds on the door sticker. That rating is supposedly not reduced by the weight of the fuel. The 4x4 and crew cab reduce the ratings significantly.
Based on what bclemens has suggested, if the Isata 5, 30 ft, is around 2,500 pounds OCCC, that sounds like a reasonable match to me = combined 4,616 before reducing it by numerous factors that are of course different between the truck and the rv.
Could go to a Ram 3500 as well as the ride is the same as far as my butt could determine when I demoed both the 2500 and 3500. The ride ability was very good on the freeway, but like all trucks rougher over rough terrain, but so are the diesel pushers.
I think many owners prefer smaller and non-truck towable, but times change and for me this combination justifies some serious consideration.
Philos3 is offline   Reply With Quote
Old 10-05-2016, 05:56 AM   #22
Kenny kustom's Avatar
If all you are looking for is payload...
get a hemi.
The Cummins is a heavy pig engine.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Bring Back The Search!
2017 Dynamax Isata 4
Old 10-05-2016, 09:01 AM   #23
Fighting the nature of things often leads to the wrong choices.
You are right. A Hemi would be a better choice for a towable.
The more the OCCC on the RV, the better as well.
The towable should mostly be the optimal daily driver, for me.
A used Force, OR, is probably my most likely purchase and a non-truck my most likely towable.
More options are available when one is not focused on the need for a warranty and one has DIY skills.
An Isata5 is an option that has a certain draw in the moment.
