Old 04-19-2018, 07:48 AM   #1
sseaner's Avatar
Isata 5 power cord reel
I finally got around to installing the cord reel. Moreryde has a tall skinny model and a short wide one. I chose the tall model to minimize its footprint and save space. I originally wanted to install it in the rear compartment but that would eliminate the possibility of using the pass through storage for my zero gravity chairs. It really does not matter because you have to drag the cord to the other side where it plugs in anyway. You have to add some sort of floor plate to mount it up. I used some 1/2 inch ply. The reel works very well and no more python wrestling.
ID:	168744   Click image for larger version
ID:	168745   Click image for larger version
Scott & Heather
2018 Isata 5 DS
sseaner is offline   Reply With Quote
Old 04-19-2018, 08:26 AM   #2
Great. Thank you. Mine should be at the house when i arrive back home.
2018 Isata 5 DS 4x4
1988 Jeep Wrangler Sahara
4XGLMPR is offline   Reply With Quote
Old 04-19-2018, 08:29 AM   #3
sseaner's Avatar
Which one did you get?
Scott & Heather
2018 Isata 5 DS
Old 04-19-2018, 08:34 AM   #4
heaston's Avatar
Hey Scott, looks good, I just bought the same reel, did you end up mounting it to the floor of the compartment or just the plywood and setting in there?
覧覧覧覧覧覧
2018 ISATA 5 DS 4X4
heaston is offline   Reply With Quote
Old 04-19-2018, 08:38 AM   #5
Tall, just as you.
2018 Isata 5 DS 4x4
Old 04-19-2018, 08:50 AM   #6
sseaner's Avatar
The reel is mounted to the plywood and the plywood is secured from underneath with some stainless steel screws and washers.
Scott & Heather
2018 Isata 5 DS
Old 04-19-2018, 09:11 AM   #7
Great job, thanks Scott for the post and photos. Now to see if I can get a powered cord reel in there?
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
caseymyers is offline   Reply With Quote
Old 04-19-2018, 11:10 AM   #8
thanks for sharing.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 04-19-2018, 03:01 PM   #9
Very nice Scott. I think your 36DS was finished 2 months before mine. Do you have three compartments on the passenger side or two compartments on both sides?
Phil Bell
2018 36DS 4x4
I5PhilGa is offline   Reply With Quote
Old 04-19-2018, 05:45 PM   #10
sseaner's Avatar
I have three on the passenger side, none on the driver side
Scott & Heather
2018 Isata 5 DS
power
