Old 11-10-2018, 01:37 PM   #1
Isata 5 Refrigerator On/Off Switch
I got tired of going to the bedroom to flip the breaker when I wanted to turn the refrigerator off so I installed a on/off switch in the panel under the pantry (pictures below). I tapped into the existing outlet under the bottom kitchen drawer, looped it through the switch and back to a new outlet to serve only the refrigerator.
ID:	191150   Click image for larger version
Phil and Jan
2018 Isata 5 36DS 4x4
2017 Jeep Cherokee Tralhawk
I5PhilGa is offline   Reply With Quote
Old 11-10-2018, 04:38 PM   #2
sseaner's Avatar
Is that for boon docking?
Scott & Heather
2018 Isata 5 DS
sseaner is offline   Reply With Quote
Old 11-10-2018, 05:12 PM   #3
The refrigerator can be turned off using the knob inside the refrigerator or turning off the inverter. Why the need for a separate switch or to turn if off?
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 11-10-2018, 06:31 PM   #4
Posted by Whaleness:The refrigerator can be turned off using the knob inside the refrigerator or turning off the inverter. Why the need for a separate switch or to turn if off?
___________
No sir, our Frigidare does not shut off by turning the knob inside to "0", the compressor still cycles on and off. We have been opening the breaker while traveling (summertime) and don't open the refrigerator to maintain temp inside. We do start the generator to run the front AC as needed and I don't want to subject the refrigerator compressor to unnecessary power operations.
Posted by sseaner: Is that for boon docking?
_____________
Yes Scott, we do "dry camp" a lot in our National Forests and at NASCAR races so this allows us to turn just the refrigerator off when using the inverter to conserve batteries. The breaker serving the refrigerator also feeds the tv's (front and outside) and some other outlets.
I just thought I would share my modification. It works for us!
Phil and Jan
Old 11-10-2018, 08:04 PM   #5
IsataMatata's Avatar
Do you have solar panels?
IsataMatata is offline   Reply With Quote
Old 11-10-2018, 08:19 PM   #6
sseaner's Avatar
You know your alternator charges the house batteries as you go down the road in addition to the solar if you have it. You really only need to turn off the fridge while boon docking if necessary. Actually a residential fridge is not designed to be repeatedly power cycled off. Itís better for it if you just leave it on.
Scott & Heather
2018 Isata 5 DS
Old 11-10-2018, 09:49 PM   #7
Yes Scott, it's better to leave it on.....or to leave it off. I do not normally travel with the inverter "on". I like to keep the batteries fully charged and ready to operate the slides. As I said earlier, I do cycle the generator on and off while traveling to run the front AC unit. As I worked for the power company for 42 years I am also aware that voltage fluctuations and frequent interruptions take a toll on compressors and electronic controls. For this reason I am more comfortable leaving the refrigerator off the majority of the time. I really don't want to have to replace the refrigerator any time soon.......similar I guess to your angst about slide motors.
Phil and Jan
Old 11-10-2018, 10:50 PM   #8
sseaner's Avatar
I just like to keep my beer really cold!
Scott & Heather
2018 Isata 5 DS
Old 11-11-2018, 10:37 AM   #9
I like the switch you installed, our fridge will not turn off with the internal knob either. I like your mod, please post us a wiring diagram, I'm not handy with ohms law.
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
caseymyers is offline   Reply With Quote
Old 11-11-2018, 03:00 PM   #10
Posted by Casey Myers: I like the switch you installed, our fridge will not turn off with the internal knob either. I like your mod, please post us a wiring diagram, I'm not handy with ohms law.
______________
Will post a diagram tomorrow when I get home Casey. You must know a few things about ohm's law if you are building an entertainment center!
Phil and Jan
refrigerator, switch
