Old 08-28-2016, 09:06 AM   #1
DavidMort's Avatar
Isata 5 Safety pressure switch for exhaust fan of hot water heater
This is the relay that lets our Atwood OD hot water heater know that exhaust fan is on, starting the ignition of the propane. The unit works when I short the wires out as if switch was working. Checked continuity by applying pressure and vacuum, but takes way too much pressure.
Where can we get a replacement? Thanks for your help!
DavidMort is offline   Reply With Quote
Old 08-28-2016, 09:08 AM   #2
DavidMort's Avatar
Other side
Old 08-29-2016, 07:40 PM   #3
DavidMort's Avatar
Brian, should we order this part through the dealer or through Dynamax. We are scheduled to go out for two weeks beginning Sept 23, and would like to enjoy hot water during that time. Thanks for your time.
Old 08-30-2016, 06:58 AM   #4
I got one from Dynamax but they just fail again...mine as well just leave the jumper on!
fred555 is offline   Reply With Quote
Old 08-30-2016, 01:05 PM   #5
GM
bclemens's Avatar
I would contact Atwood directly for replacement parts, I doubt we carry them. Also, I would like to make sure they are aware each and every time there is a failure on their stuff.
Not that I don't want to help...but I want to make sure, if they are repeat issues that they feel the grief and hopefully respond properly. So many times we see repeat issues and they supplier says "well this is the first I've heard of it"
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-30-2016, 01:10 PM   #6
DavidMort's Avatar
Thanks, Brian. I will co tact them this afternoon. Just want it fixed by9/23, which will be our first big trip. Will keep you posted.
Old 08-30-2016, 02:18 PM   #7
DavidMort's Avatar
Just spoke to Atwood, and they are sending switch out priority mail. Success. Thanks Brian.
Old 08-30-2016, 03:48 PM   #8
GM
bclemens's Avatar
I've learned to celebrate small victories...with large quantities of beer.
Old 08-30-2016, 04:01 PM   #9
DavidMort's Avatar
Cheers from Seneca Lake, NY from a practicing wino!
fan, heater, hot water, pressure, safety, switch, water, water heater
