02-17-2018, 08:19 AM
Isata 5 valve extensions
I searched but I could not find any info. I am looking for valve extensions for the two inner rear tires so I can install my last two TPMS caps. Any info is appreciated.
Scott & Heather
2018 Isata 5 DS
02-17-2018, 08:29 AM
I got my Borg extenders from Your Tire Supply for my Sprinter, but they have them for pretty much rverything. Best thing is to call them and they will determine what kit fits. You can buy just the inner extensions only and not the entire kit which has the the outer stems as well. These are not the screw on type and need to be installed at a tire shop.
Your Tire Shop Supply | Supplies for Tire Shops
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
02-17-2018, 09:01 AM
It all started with an Isata
02-17-2018, 10:53 AM
What TPMS system are you installing? Can you post a photo when you have the project finished?
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
02-17-2018, 12:48 PM
I am using the new TST color TPMS with ten cap sensors. Six for the coach and four for the jeep. I put a repeater in the cabinet behind the bedroom TV for the toad. It comes with suction and dash mount. Its rechargeable and the battery will last a very long time between charges. It tucks in nicely in the corner of the windshield.
Scott & Heather
2018 Isata 5 DS
02-17-2018, 10:09 PM
Please clarify, the new color TST monitor battery lasts a long time or the repeater battery?
I have the previous TST monitor but the rechargeable battery has a very short life. I keep it plugged in to power whenever I am driving.
It would be nice to eliminate a wire running across my dash top. Currently three up there.
2017 Dynamax REV 24RB
2018 Ford F-150
02-17-2018, 10:36 PM
I have the TST 507 color monitor and the battery does last for a week easily, I do not leave it plugged in and top up the charge as needed. The repeater does not have a battery in it, you need to connect it to a 12 volt source. I put mine in my tt battery box.
02-18-2018, 05:32 AM
My color TST monitor, once fully charged, runs a crazy long time. You will be VERY happy with how long it goes.
The repeater doesn’t have a battery. It’s hard wired to 12VDC.
Joe
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
02-20-2018, 09:19 PM
Truck System Technologies Rep
TST TPMS
Thanks for all the comments, and posts. If anyone ever has any questions, I am always available at 210-420-0132
02-21-2018, 09:31 AM
Thanks for the info.
2018 Ford F-150
02-22-2018, 05:54 PM
I just ordered a set of 90 PSI Dual Dynamics Cross fire tire system. I made sure to purchase †he one with two valve stems for the TPMS. I will post some install pics and a review of the system.
Crossfire - Dual Dynamics
Scott & Heather
2018 Isata 5 DS
02-22-2018, 06:03 PM
That looks cool. So you would only need one TPMS on the rear?
Let us know how it works and more pics. Thanks for sharing
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-22-2018, 06:16 PM
You can do one or two TPMS caps. The system keeps the pressure equal in both tires. If one develops a leak or blows out, the crossfire closes that side off and the remaining good tire inflated with just a 10 psi loss. So with one TPMS, if you were running at 90psi and it dropped to 80 psi you could assume one tire was flat. I opted for the two valve system but you still only have to fill from one valve stem.
Scott & Heather
2018 Isata 5 DS
02-22-2018, 08:16 PM
Sounds better to have 2. Keep me in the loop please.
02-22-2018, 09:41 PM
I already have the TPMS caps so I’m going with two
Scott & Heather
2018 Isata 5 DS
02-23-2018, 01:53 PM
The cross-fires are a great product. I've run them on my old RV for a lot of years, and plan to on the new DX3 we have on order. It does simplify air-ups and is a great visual indicator. Use a good tire gauge to verify the center position, one set I have it's on the red side of yellow for 90lbs.
I didn't want to mess the decorative top hats, so I mounted on the axle bolt cover and didn't run with the top hats. I found on the 19.5" tires, it was kind of crowded on the top hat and would be a pain for a tire change. This also allows to visually check wheel bolts.
A couple things I've learned over the years, they are great COLD tire indictors, they will roll to red when the tire gets some heat in them, so after a long day, just kind of ignore the color until the next morning.
One hint on installing, you actually put the INSIDE tire connection on first, then the outside (generally the 180 connector). The first one is easy, as for the second - push (pull on a 180 connector) against the air pressure in the tire as you hand tighten the nut - that goes quicker and lose less air. This way you use the wrench a lot less.
Aaron
2019 DX3 36FK
All Electric w/Cab Over
02-23-2018, 06:54 PM
What's the cost?
Old Navy Chief
02-23-2018, 08:10 PM
Amazon, about 60 each. Seen others as high as 80 each.
Aaron
2019 DX3 36FK
02-23-2018, 08:54 PM
The SVT model with two valve stems are 70 bucks each.
Scott & Heather
2018 Isata 5 DS
03-15-2018, 01:42 PM
Team Watts
If you can not get Mike, you can call me 864-985-9219
Team Watts
2017 DiXie3 Blue
37RB
Chuck, Army (Ret) & Patricia, Barber
