I have finally gotten the best of the BIRD!
I know others have been frustrated that the battery disconnect didn't seem to actually disconnect the batteries, which I've seen explained by Brian as the BIRD keeping things coupled during charging for 15 min or something like that after shore is lost. I saw this same behavior and always noticed things did eventually turn off, however it always bugged me not having a truly reliable way to disconnect the batteries.
While I was monkeying around with my solar wiring I did some poking around and think I've found a reliable solution. The disconnect on the house batteries is infact reliable, it's a mechanical disconnect that comes in on the only positive cable going to the house batteries, so that disconnect is not to blame.
As I continued poking around I found 2 things:
1. A positive cable from the chassis batteries back to the solenoid in the inverter bay. Assume this is the cable that bridges the banks with the switch as well as what the bird uses to charge the chassis batteries.
2. Two other positive cables coming off a junction block going forward. I'm wondering if the disconnect in the cab only cuts one of those?
So what did I do?
1. Relocated the boost cable (positive from the solenoid) to the chassis positive junction block.
2. Installed another disconnect (yes I know I'm up to like 5 now on this rig, hence the thread title) on what is now the only positive cable going to the chassis batteries.
Tested and now when I flip both disconnects the coach is DEAD. Like dead dead. No steps no nothing. With just the house disconnect flipped, everything stays on so I'm assuming it's running off the chassis batteries for that short time period.
This should still preserve all the functionality of the BIRD and interaction between the two banks while giving me the power to disconnect everything without having to pull the positive cables.
Let me know what you think. Be interested to know if I missed anything here.
