04-25-2017, 10:35 AM
Jenson Stereo Clock
Does anyone know how to set the time on a Jenson Stereo which is in a 2017 Dynamax Isata 3 motorhome?
04-25-2017, 12:47 PM
Do you have the owners manual? If so follow instructions after you press the mode/display button then press and hold the alarm on/off button then you can change the clock I called Jensen and the girl said they forgot to add the last step to the instructions which is press and hold the alarm on/off button
04-25-2017, 01:12 PM
Jenson clock
THANK YOU so much. I finally was able yo set the clock. I now have the correct time ☺
04-25-2017, 10:57 PM
Front tv turns on when we play CD in jensen
We can't play a cd in the Jensen radio without the tv turning on with a bright blue screen. sort of kills the mood. Anyone know how to keep the tv off? If I turn the tv off, the Jensen cd player turns off.
04-26-2017, 12:18 PM
Commercial Member
The TV is set up to use HDMI CEC (Consumer Electronics Control). This is the communication language that allows you to control both devices with one remote. Also, when you pop a DVD in, the TV will turn on and change to the proper input. IF, you want to handle all of that yourself...go into the TV menu and disable HDMI CEC. That will make both devices stop talking to each other.
04-26-2017, 01:00 PM
THANKS for the info.
I actually did try to go through the manual for this info, but with no luck. We will play music far more often than DVD's so I will make the necessary adjustments the next time I use the Jenson. Thanks for the explanation and the cure.
05-02-2017, 07:36 PM
One little known fact is that the Isata 3 has an app for the radio. Go to the App Store and search for jControl.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
05-05-2017, 01:34 PM
I got my Isata 3 yesterday and had the same issue with the missing step in the clock setup. Glad you opened this thread. I am sure many have thought their Jensen was flawed, but it's just the instructions.
Highly recommend the app, its great not to have to look for the remote.
07-04-2023, 01:04 PM
I realize this is an old thread but wanted to say thanks for the tip on setting the time as I was having the same issue.
I tried getting the jcontrol app from Google Play Store but apparently it hasn't been updated as it says it's not compatible with the newer Android version on my Samsung phone. It does download on my old cell phone (I guess there is a reason to keep those old cell phones around).
Retired IT Professional
20 years (retired) NYARNG
Lifelong Buffalo Bills/Sabres fan, avid golfer
2017 Forest River Sunseeker 3010DS
07-07-2023, 10:58 AM
UPDATE: the jcontrol app has been updated as of 7/6/2023 and is now compatible with Android 13.
