Old 09-17-2016, 06:48 PM   #1
Just bought 2016 Force 39BH HD -problems!
New to RV life and loving it but not loving the 2 return trips to the dealer
Problems thus far:
Jake break inop
Electrical issue in cab causing odometer and gauges to flip continuously
Ruptured water line leading to filter needing emergency repair while camping
Fridge not cooling
Toilet not holding water
Anyone else have similar experiences?
Forceone is offline   Reply With Quote
Old 09-17-2016, 07:42 PM   #2
no
First two are freightliner issues - they will remedy under warranty
fridge not cooling - what kind residential or Rv? how long was it plugged in for ?
water line - make sure you have a pressure regulator on the city water inlet or somewhere between your tap connect and the city water inlet. Just be thankful the ruptured outside the coach.
toilet - seal dried out. Sat too long on dealer lot without condition and dried out
word of wisdom- always shut off the water pump and/or city water when you leave the coach at a campsite. That way if there is a leak that develops, you will not be pumping water or flowing water through it while you are gone
myhorse is offline   Reply With Quote
Old 09-20-2016, 07:34 AM   #3
Had multiple issues as well when we first started out to include the fridge only cooling to 60deg. Dealer called out a Frigidaire guy and was fixed in 10 minutes (exchange fan in freezer quit/common problem).
My jake works great, but had other electrical issues, some that turned out to items simply not being plugged in; Ice maker and 12V adapter/Cig lighter didn't work - plugs not seated.
Been full timing two months now and have had only minor concerns since those first 10 days living in the service bay!
x2 with myhorse on the other concerns.
The FR guys have been great working service/warranty stuff. Hope everything smooths out and you get to enjoy the view out the window for a while!
Gabe
2016 Dynamax Force 37BH HD
2016 Jeep Wrangler Unlimited - Rubicon Hard Rock
Hey_nav is offline   Reply With Quote
