09-16-2019, 11:20 AM
Señor Miembro
key box window mark?
So there is the heavily scratched/abraded mark on my driver side window. I'm guessing it was from a metal key box or something of the sort that was used either at the FreightLiner factory or Dynamax. BC, do you know?
Is there a way to fix it without replacing the window glass?
Of course, my luck being what it is, it's right at eye level when I'm looking out the window. Or maybe if I get a new low profile chair, it'll be up out of view. Anyone else have this spot on their window?
In the pic, the spot shows as just a hazy mark just left of center, above and to the right of the long tree branch. The picture doesn't really do it justice, it looks a lot worse when you turn to look out the window and it is right in front of your eyes.
09-16-2019, 11:30 AM
Commercial Member
We don't use key boxes, nor does Freightliner. You would have to ask your dealer if they do. I don't know of any that do.
09-16-2019, 07:48 PM
Señor Miembro
Eh, even if MHSRV admits it, I'd be shocked if they'd pony up. I'll just call a glass repair place or buy a new window for it as a last resort.
09-16-2019, 08:09 PM
Commercial Member
I don't know that I have ever seen a keybox at MHSRV. All of their units are unlocked and open for viewing. I know "someone" on here brought a unit in to have a paint spot repaired that was touched up by the dealer...it was a terrible touch up job. So as always, we clean the spot first and it rubbed right off. It ended up being tape residue from something.
So, I would try rubbing alcohol or something first. I also had a scratched buffed out of glass once.
09-16-2019, 09:01 PM
Search Amazon for a cerium oxide glass polishing kit. Only about $20.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
09-17-2019, 08:51 AM
Is there a chance it is overspray? I would clean it like BC suggested, could have been a small hole in the paper mask they used to paint.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
09-17-2019, 09:37 AM
Sounds like a job for the Dynamax "Mystery Solvent"!!!
It took overspray off my windshield
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
09-17-2019, 09:42 AM
Commercial Member
Also makes for a great degreaser, aluminum free deodorant, rust remover and hiccup tonic!!!!
09-17-2019, 07:23 PM
And your laundry comes out whiter than white.
2017 Dynamax REV 24RB
2018 Ford F-150
09-17-2019, 07:29 PM
If not overspray you might try gently rubbing 0000 steel wool over the area. BTW, I use ammonia or white vinegar solution to clean my windshield from the concoction that Pennsylvania was using on roads in cold weather when glass cleaner didn't work.
2018 Ford F-150
09-22-2019, 03:55 PM
Señor Miembro
You were right!
The PDI detailers missed it. I missed it with windex wipes. My local detailers missed it. I thought for sure it was scratched. But, with a little GoofOff, it came right off! Good call on your part. I am full of chagrin that I missed it.
09-23-2019, 08:45 AM
Commercial Member
I love the idea of "assume nothing"...that way you'll never be prematurely disappointed for no reason.
