Old 05-11-2019, 09:34 AM   #1
Keypad/fob Isata 5
I have lost power to my keypad on the entry door which also renders the fob inop. Anybody else experienced this on 2019 Isata 5
mhiltom412 is offline   Reply With Quote
Old 05-11-2019, 09:51 AM   #2
caseymyers's Avatar
I haven't but I think our coach door is the same as the DX 3's and there is a thread on here about power to the door lock. I think it begins with making sure the door electrical contacts are making contact. Funny looking things at the bottom of the door at the hinge on the inside. But look for that thread there was lots of discussion about the issue.
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
caseymyers is offline   Reply With Quote
Old 05-11-2019, 11:19 AM   #3
Wonder if there’s a fuse involved because there’s no lights in the keypad and the fob doesn’t work either
Old 05-11-2019, 11:26 AM   #4
caseymyers's Avatar
It gets power from that door switch I told you about, if it is not making contact, no power. Look at the threads, do a search on the Dynamax Sub Forum this is just a couple there are more:
http://www.forestriverforums.com/for...ue-167199.html
http://www.forestriverforums.com/for...eo-166969.html
Old Navy Chief
Old 05-11-2019, 03:09 PM   #5
Should there be voltage on those contacts all the time?
Old 05-11-2019, 06:04 PM   #6
caseymyers's Avatar
Couldn't tell you but if you read some of those threads, I only sent you two of them, there was some discussion on there about how they work and all that. I've never had an issue so don't know anything about them, just trying to point you towards help with the links to the threads.
Old Navy Chief
Old 05-11-2019, 07:11 PM   #7
We are having the exact same issue with our 3 day old unit 2019 Isata 5
Was working just stopped all the sudden.
Robert Wagner is offline   Reply With Quote
Old 05-11-2019, 07:14 PM   #8
There is an 8amp fuses the wiring schematic shows. Part of the pop lock system
Old 05-11-2019, 08:01 PM   #9
caseymyers's Avatar
Read those other threads on here you’ll find the answer you need. I posted a couple here but there are more threads.
Old Navy Chief
Old 05-11-2019, 08:47 PM   #10
So the whole problem is the contacts at bottom door?
How did you fix yours?
Or you replaced all the components?
Old 05-11-2019, 09:14 PM   #11
caseymyers's Avatar
Mine has never failed, I was just offering the OP that there was several threads on the Forum that deal with his problem here are just a couple of the threads:
Keyless Entry keypad Issue
Keyless Entry keypad and Fob Video
Old Navy Chief
Old 05-12-2019, 06:16 AM   #12
I’m going to check and see if there is voltage at the contacts on door frame. Does anybody know where i fuse might be located for it if no voltage found
Old 05-12-2019, 09:34 AM   #13
caseymyers's Avatar
http://www.forestriverforums.com/for...-167199-7.html
Old Navy Chief
Old 05-12-2019, 09:44 AM   #14
Just checked the voltage at the door contacts and have 13+ volts. I guess ill have to remove the keypad and see if there’s voltage going to the keypad. Can’t imagine there’s anything but wires between the pad and contacts
Old 05-12-2019, 10:22 AM   #15
Dynamax Isata 5 FW
van_fl's Avatar
Clean the contacts on the door sil with fine sandpaper. Check fuse under steps.
van_fl is offline   Reply With Quote
Old 05-12-2019, 11:05 AM   #16
Someone on a different forum was having a similar issue and cleaned the contacts with contact cleaner and several other things with no success. Then they cleaned to contacts with a pencil eraser and it worked.
One other thing. If you changed the unlock code the key fob needs to be reprogrammed too.
Tom and Becki
2018 Isata 5 30FW 4X4
bratbros is offline   Reply With Quote
Old 05-13-2019, 08:29 AM   #17
Commercial Member
No...if you read those threads it will give you the whole story. It is either....
1. the contacts at the door not properly making contact
2. the key pad went back...there is a resistor.relay that can go bad and the keypad needs replaced. (Kredburn identified this)
Those threads are long, but give you all the info you should need.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
bclemens is online now   Reply With Quote
