Old 10-14-2019, 09:29 PM   #1
2018 Isata 5 30FW
Keypad not working 2018 Isata 5 30FW
Does anyone have experience with the electronic keypad not working. I had a problem 6 months ago and I fixed it by sanding the two square metal contacts on the lower door jamb. They were a little rusty. Now the keypad doesn't work and I can't even lock or unlock with the key fob. The metal door jamb contacts are clean. Anyone have any ideas?
Space Cowboy
2018 Isata 5 30FW
Space Cowboy is offline   Reply With Quote
Old 10-15-2019, 09:15 AM   #2
halla's Avatar
Not sure on 3 series, but our keypad went bad once and also had it blow a fuse once, the fuse for the Force was up above the step (under chassis) in a bunch of wiring.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is offline   Reply With Quote
Old 10-15-2019, 10:25 AM   #3
Commercial Member
Long thread on this...get with Pop-Locks and/or service rep and they can get a replacement keypad. Seems like the resistors in there were undersized...but at that point it would still lock and you got lights, it just didn't unlock.
IF there are no lights or anything, then could be contacts.
ONE OTHER THING....I had on a door I say, when you close the door, the pins are sort of at an angle, but if the door gets tweaked...the pins actually end up sliding OFF of the metal contacts. Hard to describer...but I noticed that with the door partially open, the keypad would light up. BUT, once I close the door completely, the key pad would not work. Finally figured out, the pins on the door side kind of pivot with the hinge.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 10-15-2019, 10:28 AM   #4
2018 Isata 5 30FW
Thanks Hala and Brian, I will check the fuse and the pin angle.
Space Cowboy
2018 Isata 5 30FW
