Old 03-11-2016, 12:36 PM   #11
Originally Posted by grumpy0374 View Post
Plumbers putty...always. Never silicone. Especially sealing plumbing fixturers.
Don't allow any silicone near my Lexi. In fact, it has a silicone early warning system. Anytime a tube of silicone comes anywhere within 25 feet of my Lexi, the horn goes off and the lights blink.
Grumpy
I like this...a silicone early warning system. I like to use plumbers putty. I am sure the MFR has its reasons for silicone. I'm not sure of the chemical pros/cons here with the exception associated with the replacement process. What a PITA to remove silicone...ouch. Let us know how it goes Slim...
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 03-11-2016, 12:47 PM   #12
Ford Idaho's Avatar
I replaced the plastic with SS and putty in the kitchen sink, no leaks as of last fall.
Old 03-11-2016, 01:21 PM   #13
KyDan's Avatar
Looks great!!
We have upgraded most of the plumbing fixtures in our trailers over time.
Plastic faucets and cheap shower wands-- ugh!! All gone now.
You did good!
At least our new rig came with a porcelain potty!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 03-11-2016, 02:31 PM   #14
AWF1945's Avatar
Grumpy
Lol.. was that system an option
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 03-11-2016, 02:32 PM   #15
grumpy0374's Avatar
I replaced the kitchen and bathroom plastic fixtures with some quality home style fixtures I found on Amazon, along with replacing the fittings to the faucets with some stainless braided water lines with cut off valves.
The funny thing is the quality fixtures only cost a few bucks more than the POS plastic fittings.
As for silicon...I can't see any use for it on an rv. Just no place for it as there are too many quality caulks and sealants out there that are the proper ones to use. Only reason I can see for it's use is that it's cheap, and used as a cost cutting measure.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 03-11-2016, 02:33 PM   #16
AWF1945's Avatar
Originally Posted by bclemens View Post
"You're" a dummy
I will print this off for the line and see what we're doing today. I'll also take a look at the drains. Those solid surface sinks aren't cheap, but I have always preferred stainless steel. Those things are bullet proof and no reason to be using plastic on either.
Thats what I thought too..
Old 03-11-2016, 02:51 PM   #17
AWF1945's Avatar
Grumpy
Most if not all shower stalls are sealed with silicone, thats a PITA too when you get a leak. Its just a pain to remove. Share what your using in place of it. Thanks. .
Old 03-11-2016, 03:03 PM   #18
grumpy0374's Avatar
Latex bathroom/kitchen caulk. Much better than silicon. If thats what they use to seal the shower stall, than I'm lucky, cause the brain surgeon who installed the stall on our Lexi forgot that step. There was no sealant used, and when I saw what was missing did it myself using latex sealant. Sealed shower door to wall, and shower pan lip, and ran a bead around lower area seam where shower walls overlap the shower pan. Also ran bead around kitchen and bathroom counter tops where they meet the walls.
Two years now and no problems, no leaks.
It's available in white beige/cream color, and brown. Lowe's, Home Depot carry it in a large toothpaste type tube.
Look for Dap Kwik Seal Plus, or anything similar. If it states somewhere on the packaging that it's paintable, then that means there is no silicon in it.
Grumpy
Old 03-11-2016, 04:23 PM   #19
AWF1945's Avatar
Thanks, I have some of that called Dynaflex by DAP. Guess I'll dig it out and redo shower.. I'll use Dynaflex on my Dynamax lol :-)
Old 03-11-2016, 04:32 PM   #20
AWF1945's Avatar
Tell ya something even better than Dynaflex. Its a product made by loctite. Tub and Tile no silicone, it goes on whitish dries clear. I used it before too. I did find an old tube in my box. Need to get a new one.
drain
