Old 03-11-2016, 09:19 AM   #1
AWF1945's Avatar
Kitchen sink drains!
Correct me if I'm wrong please. Isn't plumber's puddy supposed to be used on sink drains? Mine has leaked under the cabinet making a mess. Luckily i had a plastic tote under there that caught the water.
I pulled apart and its sealed with silicone. .. lots of it.. and it's hard to remove. The plastic drain insert swims in that hole. Its not snug. Was that installed like that at the plant. ? Its a terrible fit really.. picture to follow.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 03-11-2016, 09:27 AM   #2
AWF1945's Avatar
Should have took a picture before I started removing silicone. .
ID:	101626   Click image for larger version
Old 03-11-2016, 09:39 AM   #3
AquaMan's Avatar
The problem with the putty, is the plastic drains are fairly cheap and to get enough pressure on them to squeeze the putty, they would probably strip threads or break. Using silicone is acceptable and probably warranted in this situation because of the flexing of a trailer. I would pull it and reseal with a nice bead of silicone.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 03-11-2016, 09:46 AM   #4
KyDan's Avatar
Not trying to argue but fresh plumbers putty at room temp is VERY soft.
It would/should work fine to seal that drain- plastic fittings and all.
Silicone sealer should work fine as well but it's much harder to remove if
you ever need too.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-11-2016, 09:48 AM   #5
Head Rambler
It should have had a ring of plumbers putty to seal between the drain flange and the sink and also a rubber ring below the sink.
I seriously doubt that many, if any, installers go the trouble of doing it right in these units.
Gotta go campin!
Old 03-11-2016, 10:03 AM   #6
AWF1945's Avatar
Thanks for the replies. No putty at all. Globs of silicon. Ridiculous, yes it had rubber seal underneath. I'll start with putty and go from there. Geez..
Old 03-11-2016, 10:30 AM   #7
bubbles's Avatar
Ummm, what!
Old 03-11-2016, 10:31 AM   #8
grumpy0374's Avatar
Plumbers putty...always. Never silicone. Especially sealing plumbing fixturers.
Don't allow any silicone near my Lexi. In fact, it has a silicone early warning system. Anytime a tube of silicone comes anywhere within 25 feet of my Lexi, the horn goes off and the lights blink.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 03-11-2016, 10:55 AM   #9
AWF1945's Avatar
Okay problem solved. Replaced plastic sink drain with a real one ;-) plumber's putty Teflon thread sealer on metal to plastic trap pipe ... there ya have it. I'll do the other sink when my fingernails grow back from removing that silicone. Silicone has its place. ... but not for this. If your reading this and your the one that did this to my Dynamax. . Your a Dummy! :-) lol The new drain matches the faucet hardware better.. and before anyone askes, no.. the sink is not plastic. Thanks for the replies... no damage done.
Old 03-11-2016, 11:40 AM   #10
GM
bclemens's Avatar
"You're" a dummy
I will print this off for the line and see what we're doing today. I'll also take a look at the drains. Those solid surface sinks aren't cheap, but I have always preferred stainless steel. Those things are bullet proof and no reason to be using plastic on either.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
drain
