Old 07-28-2017, 02:26 PM   #1
Landing Gear
Today I noticed hydronic fluid pooled in the rear driver landing gear foot. I did recently extend out all the way. Is this ok or something I need to look into?
Jammer151 is offline   Reply With Quote
Old 07-28-2017, 03:22 PM   #2
Three months ago had similar problem with drivers front.
Was all the way extended. I saw some leaking on the piston coming from
the seal. I had to add some fluid to the system after jacks were retracted
and MH moved to level spot. I have power gear levelers and after talking
with them not to over extend, started to put blocs or what ever under
jacks so they would not over extend. Since doing that, I have not had
any leakage around the seal, and all seems well. I check them all the time
now to see if any are leaking.
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
joet19711 is offline   Reply With Quote
Old 07-28-2017, 06:20 PM   #3
Good info... may be same issue here. I will keep watching.
