Originally Posted by bclemens
I do know that setting the water level you have to hold both buttons down AFTER you have drained it dry. AND, depending if you are on pump or city you have to reset it each time you change water source (the fill at different rates).
If I recall correctly. You press both quickly to drain dry for travel. Then you press and hold both as it fills up. Let go of both just as the water gets above the hole line. Worked for me.
What could also be happening is if you are not perfectly level, maybe that rear tube is on the low side and it is siphoning out the water??? I think Casey had this issue as well. It worked at our place, but that is level. Might need to raise the internal rubber pipe a little more to prevent that issue when slightly out of level? Or maybe the buttons are not getting held down at the same time.
I hate sound dumb, but it won’t be the first time...where are these buttons located to set the water level?
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
