04-07-2019, 06:43 AM
Learning the AV on my 2019 DX3
What’s the best resource to learn how to work with all the components?
04-07-2019, 07:51 AM
You're here. This forum. Just ask questions and people will jump in to help
2016 Dynamax DX3 - Big Blue
04-07-2019, 08:18 AM
OK, where do I start? I couldn't even figure out how to play a DVD! I feel behind the technology curve on this!!!!
04-07-2019, 09:11 AM
Sorry, someone with a 2019 could help you
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
04-07-2019, 09:40 AM
I guess maybe start with what you've tried?
First things would be to figure out which input on the TV the DVD player is on. Turn it on put a DVD in and cycle through the inputs.
04-07-2019, 10:33 AM
Commercial Member
04-07-2019, 02:20 PM
Is there a power tv antenna on/off?
04-07-2019, 03:05 PM
There's a black switch panel with a small little black button and a green LED. Push it in and it'll power up the TV OTA antenna booster. Turn it off and it'll let you use the cable hookup. Be SURE this is off when you attempt to use the cable connection as it toggles between cable and OTA
04-07-2019, 03:22 PM
I understand the operation as my Seneca had that but I have no idea where it is!!!!
04-07-2019, 03:54 PM
Mine is next to my satellite and awning controls but that's a 2016
04-07-2019, 07:34 PM
In our cab over model, the switch is up in the bunk area, above the satellite switch, behind the swing out tv.
2018 DX3 37BH
04-08-2019, 07:13 PM
Found the antenna pwr
04-08-2019, 07:14 PM
I have one tv that will hook up to the blue ray. This is real exercise in frustration
04-08-2019, 07:29 PM
So if the tv in the bedroom works with the blue ray when the matrix is off, does that mean the cables are run the wrong way?
04-08-2019, 08:19 PM
Only one hdmi cable runs to the rear bedroom. The blue ray goes to the rear TV. Shouldn’t the BlueRay go to the matrix?
04-08-2019, 08:22 PM
Not trying to high jack the thread but I'm kinda in the same boat. I have 2016 37 BH DX3. Ive had several motorhomes with all kinds of different Sat, cable and TV hook ups, But I'm at a loss here. Not sure if the last owner changed stuff or took something with him. So in the cabinet to the right of the TV there are three RG6 coax's coming in. I'm guessing one is from the King dome since it had a DirecTv fliter connected. What are the other two? OTA/cable? But then what is the other? How does any of the signals get sent to the bedroom or out door TV? There is a 1 into 2 HDMI spliter behind the main TV. The HDMI that comes out of it heads over towards the driver side of the coach , I have no idea where it goes.I feel like I am missing some sort of spliter that you can select different sources and send them to different TV's. In the bedroom there are two RG6 coax.. Im confused,,lol
2016 Dynamax DX3 37BH
2015 Jeep JKU
04-08-2019, 08:48 PM
They are different. I’m thinking the rear BRay is only for the rear. While the front BRay feeds the matrix. Can someone tell me if I’m right or wrong
04-09-2019, 10:00 AM
Commercial Member
Which Blue ray??? There is a Blueray in the front. That should go to the matrix. For a while, the DX3 was getting a blue ray in the bedroom and it was not supposed to, that was for the XL only which will only feed the bedroom TV.
If you explain what you are trying to do, I can try and help. 2019 DX3, but what floor plan, what options (fireplace, entertainment center?? etc). Once I know that I can try and help.
04-09-2019, 05:50 PM
DX3 TS w fireplace and TV with overhead bunk and Tv
There is a rear blueRay and a front blueray.
I got the ota tv working and rear blueray works
Trying front blueray tonight
04-09-2019, 07:31 PM
Commercial Member
The front Blue Ray is designed to feed the fireplace TV and outside TV. The front cab-over TV was actually not supposed to be there as the fireplace TV was supposed to replace it. However, there was some confusion there and many got the TV, but that also meant there was no HDMI routed to that TV as it ends up getting routed to the fireplace TV.
