Old 05-21-2018, 01:48 AM   #1
esp
led dimmer (s) needed
I just got a 2018 Isata 3 and the led's are way too bright. I took off the bezal and lens to check the bulb, but it is integrated into a small module. I had found 12v led dimmers and am not sure if they will work with this lighting setup. I would prefer dimming to lens darkening. Any ideas?
esp is offline   Reply With Quote
Old 05-21-2018, 09:06 PM   #2
Magnatudes's Avatar
Double Dimmer
Single Dimmer
2018 Isata 3 24RW
Downsized from 2004 Country Coach Intrigue
Magnatudes is offline   Reply With Quote
Old 05-22-2018, 07:58 AM   #3
Loefflerh's Avatar
That was my solution for the lights over the dinette - same problem, uncomfortable bright. The little module is hidden in the wall behind the original switch and works perfect!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - ?
Loefflerh is offline   Reply With Quote
Old 05-25-2018, 10:59 PM   #4
esp
Originally Posted by Magnatudes View Post
I ordered one and although it is smaller, I could make do, but mine has a white wire in and out vs, 4 wires for these switches.
Old 06-21-2018, 03:41 PM   #5
The problem I ran into is that the 4wire dimmers require you to find the negative from the LED string and disconnect it from the frame and run it back to the dimmer. I have no idea how that would be accomplished on my RV since I haven't found a wiring diagram for it. Now I have 2 of these devices and no way to use them.
'04 Dodge Ram 2500 CTD 4x4
-Edge CTS w/ hot unlock
-Goerend billet input shaft & low stall T/C
'18 Rockwood 2509S
Charles in TN is offline   Reply With Quote
led
