02-10-2017, 09:52 AM
Led light strip and Sony radio
2016 Force HD 36FKS. Led light strip is not working on Awning. Where would the fuse be located for that? I have looked everywhere. Also Sony radio has issues. As soon as FM is turned on it plays for 5 seconds and shuts off. I wish it could monitor rear of coach when I am traveling rather that just backing up. Thanks for all the help in advance.
02-10-2017, 10:26 AM
Commercial Member
It should be fused with the awning, so if the awning is working, then its probably the light strip as opposed to the fuse.
To monitor the rear of the coach you could wire up a switch to provide power to the back up wire. If you search this forum, I think a DX3 owner gave instructions on how to do it.
02-10-2017, 10:42 AM
LED lites
Originally Posted by Tugboat609
2016 Force HD 36FKS. Led light strip is not working on Awning. Where would the fuse be located for that? Thanks for all the help in advance.
One day ago i replaced both awning LED lite strips on my 2015 Rockwood 5ver as they were weak. the smaller awning, mounted on the rear slide out, has an independent switch and worked without issue. the awning over my main living and entrance area would not work. i knew it was previously working so i went to see my friendly local dealer and talked to the service manger who proceeded to tell me that the main awning and seperate awning LED switch, which were both located in the main switch panel, had an awning light fuse. he stated, "this is where the manufacturers put them because the main fuse panel would not accommodate the awning lights". after removing the panel and taking a good look, guess what was coming off the power lead of the awning lite switch? you guessed it. a 5amp fuse & holder. i now have all LED lites working.
i did not take a picture but my repair was pretty straight forward. i hope this helps with your camper model.
blessings
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
02-10-2017, 11:03 AM
Where would the awning fuse be located? The awning works. Just the strip is dead.
02-10-2017, 11:49 AM
Commercial Member
It is Fuse H8...but that also feeds the porch light and entry light. If those are working, it is probably the plug. When you're rolling the awning out, you'll see the wire coming off the arm, follow that to a plug. That plug can work its way loose or gets corroded. When we see one not working, we take it apart and put dielectric grease in there.
02-10-2017, 12:58 PM
Awning LED switch fuse location
The main awning LED lite switch, which on my camper is located on the main switch(es) panel, and is different and independent from the awning switch, is located behind the switch in-line on the positive/hot wire just inches from the switch itself. I would think this is pretty close to most campers fuse install.
hope this helps.
tmfaulksr
the faulks & prince
2013 BMW R1200GSW
02-10-2017, 06:26 PM
Our Force awning led light is tricky, we have to open/close it a little to get the light on. May not be a fuse
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-10-2017, 06:40 PM
Fuse
I've got a Columbus and found the fuse behind a square plastic inspection cover where the washer/dryer go.
02-10-2017, 10:08 PM
Halla, I never tried that. I will give it a shot tomorrow when it warms up a bit. I just purchased my rig late October. Haven't had much time to work kinks out yet. Been cold in New Jersey. The unit I purchased is former Force owner Mikes. He traded it in on a fiver. It is a early 2016 build. I will hopefully have most of kinks out by April or May. Thanks Halla
02-11-2017, 09:05 PM
Love our Force, proly around the same age as yours. Going to post my modifications page soon.
02-12-2017, 07:11 AM
I love our Force HD also. I traded a 2015 Cedar Creek Touring Edition Fiver and a 2015 F350 SuperCrew and never been happier. The wife and I are really only available on weekends to do stuff so this was a great alternative. I love the fact I am completely self sufficient now, no matter what we decide to do. Look forward to that list of modifications Halla!
