Old 07-09-2016, 08:19 PM   #1
LED Lighting
Name:	ImageUploadedByForest River Forums1468113146.605487.jpg
ID:	113596Click image for larger version
Name:	ImageUploadedByForest River Forums1468113176.725218.jpg
Lower bath sink light LED lighting is flickering. Top LED lighting works fine. Both lights are connected to the same switch. Fuses and GFCI are good. I assume this needs to be replaced.
I cannot find a disconnect. Do I snip the electrical lines and resodder the new LED lines?
Anyone have to replace an LED light in a Dynamax DX3 or Force?
Mike
2016 Force HD
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 07-10-2016, 08:45 PM   #2
Brian-can you send me a P/N for a LED light fixture. I am sure I should me able order a replacement part from some company.
Thanks, Mike
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 07-11-2016, 10:32 AM   #3
GM
bclemens's Avatar
plastic or glass cover?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 07-11-2016, 01:29 PM   #4
Glass cover
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 07-11-2016, 01:31 PM   #5
To re-state, it is the LEDs I need to replace. The LED is flickering. The glass cover is not broke.
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 07-11-2016, 02:08 PM   #6
GM
bclemens's Avatar
Understood. Just wasn't sure if they were two different fixtures based on the cover. it appears they are not.
We get those from Command, K-57L32 appears to be the part number.
Old 07-11-2016, 05:09 PM   #7
Thanks. I should have know Command would also ask for me for the fixture Model Number. When you get a few, could you provide Model # as well please. Thanks.
Mike
2016 Force HD
Mike
2016 Force HD 36
Old 07-12-2016, 09:13 AM   #8
GM
bclemens's Avatar
K-57L34/K-58L34: GLANTASTIC GLASS OR PLASTIC LENS LED CEILING & UNDER-CABINET LIGHT €” Command Electronics
Not sure they really give me a model number.
Old 07-12-2016, 02:43 PM   #9
Strange my Bathroom whent out the same way, after the first few days on our maiden voyage.
I need one sent out as well
It might be time to drop this thing off at a FR dealer, the list goes on...........
2016 Dynamax Force 37BHHD
724Bravo is offline   Reply With Quote
Old 07-12-2016, 04:16 PM   #10
GM
bclemens's Avatar
Once you get a proper shake down, just get us the list (really Matt in service). best case is to let the dealer take a look, verify what parts and then take your unit back. Use it and then when parts are confirmed in, drop it off to minimize the time you don't have your coach.
I think Matt has a guy down there in SoCal that does a good job for us.
led, light
