03-19-2019, 08:29 AM
#21
Change brands. Get a Dometic ceramic. has a horizontal slide valve. I put one into our first motorhome and did not have the problems I had with Thetford. My Prime time 5th wheel came with a Dometic and have had no problems in five years
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
03-19-2019, 11:27 AM
#22
A lot to be said about having an elongated bowl, soft closing seat, ADA height, non-macerator for flushing without water.
Cassette toilets are interesting as well.
03-19-2019, 12:03 PM
#23
Have a thetford aqua magic ceramic bowl . fours yrs full time never any issues
03-20-2019, 05:44 PM
#24
I love this board.
I too had a seeping problem. At the end of last year I tried 2 bottles of seal conditioner. Perhaps it helped a little but it didn't cure the problem. This spring it was going to be replace the ball and seal time. If that didn't work, the whole toilet was going to go.
I come on this board after a short absence and there is the answer waiting for me. Let the sucker slam shut!!! Problem cured. I really appreciate you guys. You are a mine of totally useful information. Thanks.
03-28-2019, 06:28 PM
#25
Originally Posted by houstonstroker
Ours will do that unless we let the valve slam shut.
Same here....^^^^^^
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnebago Adventurer 38Q-26K Chassis...traded in 2015 Wildcat 282RKX
Towing 4 down 2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite or 2018 Colorado Crew Cab 4x4 V6 longbed
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
03-28-2019, 07:08 PM
#26
We spray the ball and adjacent area with a silicon spray periodically and that eases the intensity of the slam needed🙄
Fred & Ellen
2018 DX3 37TS
Disabled Nam Vet
2020 Diesel Rubicon Unlimited with stuff 🤪
03-28-2019, 07:13 PM
#27
We periodically spray the ball and adjacent area with a silicon spray after shutting the water off and opening the ball with the pedal. That eases the intensity of the slam needed to hold water.
Fred & Ellen
2018 DX3 37TS
Disabled Nam Vet
03-28-2019, 08:37 PM
#28
Vaseline!!!
We had the same issue, and got an advise from an Old RVer...he told us to get a pair of latex gloves, paper towels, disinfectomg wipes, and Vaseline! Shut the water off, make sure no water is tricking down, use paper towels, clean the black seal on top and below with the wipes, dry it really good with paper towel, and take the index finger with about a dime size dab of Vaseline. Rub around the underside of the black seal all around, and let the flap go in and out with the pedal! Turn water on, and that should end the problem! If it doesn’t, then it would be a more serious matter! We have tried the above several times in our 3 year rig and it worked like a charm!!! Hope it helps!
03-29-2019, 05:27 AM
#29
Plumbers grease?
Home Depot has small tubes of plumbers grease. It’s a Heavy petroleum jelly. I’m going to try it.
03-29-2019, 05:42 AM
#30
I always keep a spare toilet in our TT. Side storage compartment...has small shovel, Roll of TP on a hook. Go into the woods...dig a hole, let it go, fill it in...that's the end.
03-29-2019, 09:38 AM
#31
A good old fashioned military entrenching tool. Every camper should have one.
03-29-2019, 09:41 AM
#32
Yes Sir !! comes in very handy in an emergency.
03-29-2019, 10:04 AM
#33
Recently new!
Should be standard equipment on any outing.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
03-29-2019, 11:08 AM
#34
Originally Posted by latner
I bought a Dometic 310 that leaked right out of the box...the fix was to fill the bowl with hot water and let it sit until the water cooled, basically reshaping the rubber seal to the ball.
This worked on our new 5er as well.
It hold the anti freeze all winter
Cheers
03-29-2019, 03:00 PM
#35
Well this has been I-n-t-e-r-e-s-t-i-n-g. This next trip I will let it slam shut. Of course this is guaranteed to wake the DW around 3 am.
As stated I have already replace the ball seal. So will try the hot water also.
If that doesn't work then goodbye Thetford plastic throne. Move to a Dometic Ceramic.
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
03-29-2019, 03:38 PM
#36
Can't speak for the plastic thetford . but the aqua magic with the porcelain bowl i don't have to slam it shut . every few months it's just clean and lube the seal and all is good for another few months . you'll have the same issues with a dometic after awhile the seals will need to be cleaned and lubed . seem lots of dometic toilets that don't holds water and seems people for the most part don't seem to care . on this forum people are more prone to taking care of their units
03-29-2019, 10:28 PM
#37
Originally Posted by kenandterry
Personally I don’t see this as a Dynamax issue as much as the toilet manufacturer.
Is it a Thetford or Dometic?
What model number?
It can be a Dynamax issue, as they do not install the flex drain line correctly like on my I5 and the water siphons out of the toilet.
I think some of you forget, improper installation affects how many of the appliances work.
03-29-2019, 10:57 PM
#38
54 Years, 13 RV's
Replaced my creaky, leaky Dometic 300 with a porcelain elongated bowl model Dometic 320. Just finishing up a 10 day trip and I absolutely love the 320.
2021 Rockwood 2511S
2020 GMC 1500 6.2L
