I wish I had automatic levelers.... unless they weigh too much and reduce cargo capacity. I have to use leveling blocks; may require several tries , of driving back and forth, to get the rig 'close enough' to level. I was using a small bubble level; I placed it right in front of the fridge on the floor since I think that is the most important area to insure is level. I recently downloaded , for free, a neat application from Truma. We don't have their water heater, but anyone can use the application. You use your phone as the level;the application tells you how much each wheel is 'off level', in inches. Then I have a better idea of how many blocks to use under the wheels that need to be raised. I am still experimenting with it, but it seems to work well. I have yet to use it to level our rv with the slide in, and then check to see how much the slide has caused that side to tilt. I hope to be able to routinely add that figure to the left side wheels when adding blocks to compensate for the slide tilt.
