10-30-2017, 10:24 AM
Light Bar in Place of Fog Lights
The headlights on these units leave much to be desired for night driving. I bought an LED Light Bar from Amazon to replace the yellow fog lights. After removal of the lights and metal plate I tried for hours to figure out how to mount the Light Bar in the existing fog light holes. The mounting bolts for the light bar can be outside the light or inside the light, but nothing fit quite right.
I tried to fashion some metal bracket to attach to the fog light holes but this didn't work either.
So I stepped back fro a moment and and thought let me look up. Sure enough there were two holes in the top metal bumper area that worked great. No drilling required. I simply flipped the light bar brackets 180 degrees and mounted the bar up instead of down.
I was getting ready to leave on vacation so for now the existing fog light switch was used for the trigger on the automotive 30 amp relay.
I will switch this and make the trigger the high beam. When I hit the bright light switch I want all available lighting to come on.
DYNAMAX 2016 FORCE HD
10-30-2017, 11:06 AM
Are those legal for highway use
I have a Jeep and was told off road use only.
10-30-2017, 11:19 AM
Broken Toe
We have an idiot kid around here that has one at the base of his windshield on his truck, and he runs around with it on all the time and refuses to dim it to oncoming traffic. It's the most blinding thing I have see short of staring into the noonday sun.
One of these days, he is gonna cause a wreck.
tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
10-30-2017, 04:20 PM
10-30-2017, 04:36 PM
I am getting ready to list my HID Projector lights I had made by HIDProjectors on ebay.
I ordered a new set for the HD, has an amber back light now.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
10-30-2017, 07:35 PM
They are illegal in most states for on road use.
Scott & Heather
2018 Isata 5 DS
10-31-2017, 06:17 PM
Light Bar instead of Fog Lights
10-31-2017, 06:36 PM
For on road use they should be aimed to fill in between the head light and the dark spot in front of the vehicle. Everyone wants to light up the sky!
10-31-2017, 08:18 PM
Led light bar illegal for on road use
Led light bars are illegal for on road use in most states.
10-31-2017, 09:02 PM
Restricting the air flow to that cooler might not be a great idea.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
10-31-2017, 09:39 PM
I too hate to see them in use on the highways. Have quite a few around here that think they are cool or something to use them all the time. Wish the law would start writing tickets for them.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
11-01-2017, 02:11 AM
Illegal
That is considered an OFF ROAD light fixture. They are NEVER to be run on the highways and roads at any time. They are illegal in most all states. Trust me, the first time you hit those and a Trooper sees you, you better have a BIG pocketbook.
11-01-2017, 04:24 AM
I have them on mines and wouldn't think to use them on highway, when I was coming from Las Vegas going through UT area it was dark and their wasn't no street light around for miles so I use them for that and coming into the camp ground until I was able to see with my hid's.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
11-01-2017, 05:44 AM
I believe it's industry standard that automobiles and trucks with Fog lights, the Fog lights are shut off when the High beam is active. My F150, 1500 and 2500 were all like that. Turn of HB and the FL shuts off.
11-01-2017, 07:59 AM
I think the HID projector headlight replacement is the way to go. I'd have bought Halla's if the DW hadn't already ordered a set for me for my birthday.
I also swapped the bulbs in the fog lights for LED bulbs. This helps a bit too.
The LED bars are definitely cool and produce a lot of light, but if they are for off road use only then I wouldn't get much use out of them...and sure don't want to put a damper on a trip by getting a hefty ticket.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
11-01-2017, 07:57 PM
I've never used them to replace fog lights but have had them on several vehicles as driving lights. They need to be covered when not in use and have to be wired through the hi beam circuit here in BC. As mentioned, use them wisely. Make sure you turn them off as soon as another vehicle shows up no matter how far away they are. I've used them for 10 years and have never had an issue with authorities.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
