09-02-2016, 02:08 PM
#121
Originally Posted by bclemens
Which keyless entry do you have? The one with the buttons on the latch, or the one with buttons down below on the door?
If it's the bauer with the numbers on the latch.
Have you reset the code or is it still on the default?
The default is 3-7-1-5, then hit the button with the key on it.
It is the Bauer EM. I have reset the code. The key will not go all the way in so I believe they gave me the wrong set or it was delivered to them with the wrong set. The literature says you should be able to lock both the dead bolt and the paddle with the key. The keyless pad will unlock the dead bolt but will not lock it. I am going to change the batteries to see if that works for the keyless. Do you need the VIN of my coach?
09-02-2016, 02:27 PM
#122
Commercial Member
What literature says you can lock the paddle and deadbolt? Keyless entry does not lock the paddle, nor will a key. its only deadbolt...otherwise you could lock yourself out with the keyless entry.
Even the wrong key would go in all the way. Sounds like, maybe someone broke something off in there.
09-02-2016, 02:33 PM
#123
The literature that I found on the Bauer website located here:
http://www.bauerproducts.com/wp-cont...s-21Apr-15.pdf
In the features it states: " The key will always be able to operate the paddle or dead bolt lock in case of the user forgetting the code or dead battery"
09-02-2016, 02:54 PM
#124
Commercial Member
Paddle OR deadbolt, not AND. On the keyless entry they only ever have one being lockable as far as I know.
If it unlocks, it should be able to lock via the same process (but you have to wait a little bit I think). Code plus the key button
09-02-2016, 03:59 PM
#125
Well, I spoke with a representative at Bauer and she informed me that the reason the key won't go all the way in is because the lock cylinder was installed incorrectly. The key slot must be installed in the 12:00 position and mine is in the 1:00 position. Now I'm forced to travel 350 miles to the dealership to have it installed/re-installed correctly. She told me she would have it repaired if I wanted to remove the entire assembly and ship it to them, but I'm a little anxious about doing this myself because there is caulking around the outside of the lock frame. Don't want to mess up the paint. I wonder how this unit made it all the way to the dealership without anyone noticing this???Hmmmmmm...
09-02-2016, 04:38 PM
#126
Commercial Member
We probably need to add that to a checklist. Door mfg installs the lock, we hardly ever lock them because we are a gated facility. If we do lock them it's normally with the keyless entry. Who's the dealer? they would/should have locked it.
09-02-2016, 05:05 PM
#127
The dealership is Dennis Dillion RV in Boise, ID, not sure how they didn't catch it, but stuff like this happens as we all know. I've contacted them and they've put me in touch with the Dynamax representative who's name is Joe. Good idea on adding it to the checklist. The door manufacturer should add it to theirs as well. Thanks for all your help. You guys rock!
09-07-2016, 02:22 PM
#128
Brian, are any Isata 5 going to be at the Dallas RV show coming up weekend after next
09-07-2016, 02:31 PM
#129
Commercial Member
Might be a 35DB. (3) 36DS's have shipped down and they all sold within a week.
09-07-2016, 02:34 PM
#130
Thank you, before I pull the trigger on one I have to see it in person. I'll just have to keep on trying to find one to look at ughhhhhh
09-07-2016, 02:37 PM
#131
Just asking here, is there anyone in Texas that has a 36DS that I could take a look at. Wife n I would be very grateful.
Thank you
David
09-07-2016, 03:01 PM
#132
Commercial Member
Sorry about that David... I misread the floorplan you are looking for. The Isata 5 has been very hot and is somewhat hard to find. I know Motorhome Specialist (just south of Fort Worth) has a couple on order, but that's really about it for Texas right now. There should be one in Mesa, AZ at Desert Autoplex and another at Lazy Days in Colorado just north of Denver.
(800)-335-6054
5411 South I-35W
Alvarado, Texas 76009
Desert Autoplex
(480)-964-2277
2260 E. main St.
Mesa, AZ 85213
Lazy Days - Colorado
(855)-328-0328
4777 Marketplace Dr.
Johnstown, CO 80534
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
09-07-2016, 03:11 PM
#133
Commercial Member
Longhorn has a 35DB Isata 5 in stock. Motorhome Specialist should have a 36DS towards the end of the month.
09-07-2016, 03:16 PM
#134
Thank you, I've been talking with both of them Coop at longhorn and Justin at Mhsrv. Both saying the end of the month for the DS. Gonna drive down to longhorn this weekend n look at the DB version if it's still there, fingers crossed.
09-08-2016, 03:10 PM
#135
Another question been looking but haven't found examples of color schemes of the outside of the 5s. Is there more than one
09-08-2016, 04:02 PM
#136
Commercial Member
We only had the one. We are about to debut (3) more. Not sure I have pictures yet.
09-08-2016, 04:19 PM
#137
Commercial Member
Here are the three new colors. The cosmic Blue and the Cabernet are actual photos while the Sunset is just a rendering for now...
09-08-2016, 05:35 PM
#138
Tyvm much appreciated
09-09-2016, 07:11 AM
#139
Commercial Member
I was told that I can make this show up as a photo rather than an attachment... let's see if I can make it work.
09-09-2016, 07:46 AM
#140
it worked!
