put a flat washer and then lock washers on them. There will be movement to the assembled area and the bolts my loosen a little. with locktight on the bolt/nut will hold the bolt/nut 'together', but the bracket area can still loosen from movement. Same thought when changing a tire, tighten to torque and then 25miles down the road re tighten.
Tighten these bolts (with lock washer) and after several usages, re tighten again.
Brother Les
