Old 12-08-2019, 05:21 PM   #1
viperdave's Avatar
Lost 12V inside DX3
I returned from quick trip to the sand dunes with all going well. Plugged my rig in the following day to shore power and discovered that no 12V is working inside the coach. Batteries are charging, I have 110v inside the coach. Xantrex is working, front slide works but nothing else operates. The rear slide will not move, coach and generator starts.
The 12v fuses below by the inverter are ok and I seem to have 12v running through the relays down there. I found one spot where 12v wasn't flowing through but don't have a picture. It looked like a relay with an additional circuit board and a fuse on it, unlike the other normal looking relays.
Any ideas???
Thanks!
2016 Dynamax DX3
viperdave is offline   Reply With Quote
Old 12-08-2019, 05:47 PM   #2
Jpheifer's Avatar
Any ideas???
Thanks!
Did you check your 12v fuses ate the power center where the 120 breakers are?
Joe Pheifer
DX3
Jpheifer is offline   Reply With Quote
Old 12-08-2019, 05:49 PM   #3
viperdave's Avatar
yes, pulled them and verified with voltmeter that no 12v is active at the fuse panel inside by the 120 breakers.
2016 Dynamax DX3
Old 12-08-2019, 05:50 PM   #4
Jpheifer's Avatar
I think in the bay by the inverter there is a master 12 v breaker that takes 12v back to that panel - check it there is more than one in there
Joe Pheifer
DX3
Old 12-08-2019, 09:36 PM   #5
have you checked this relay? feed Your 12V panel, mine is under the King bed
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2019 Ford Explorer
2018: days camped 126
2019: days camped 97
2020: days camped 0
joet19711 is offline   Reply With Quote
Old 12-08-2019, 09:40 PM   #6
also this, it would be the relay in the upper right corner
Name:	elec comp fuses and relays.jpg
Joe & Kathy
2020: days camped 0
Old 12-08-2019, 09:49 PM   #7
viperdave's Avatar
that is the one Joe! Mine is down below by the inverter. It was the only place down below that I couldn't get 12v with the voltmeter. The fuse looked ok but now that I think about it, I didn't verify 12 volt at that fuse either.
So am I to think that the relay is bad then? What is the name of that relay or how to I find out what/where to order?
Thanks for your help and great photo!
2016 Dynamax DX3
Old 12-08-2019, 11:49 PM   #8
AWF1945's Avatar
Not trying to redirect by no means... but what a huge difference in wiring from 2015 to 2016.. looks like a complete change. I will be following this post.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 12-09-2019, 06:55 AM   #9
Jpheifer's Avatar
I was trying to help - but mine is. 2015 as well and it looks very different as you said
Joe Pheifer
DX3
Old 12-09-2019, 07:04 AM   #10
Pretty sure this is the one
https://www.amazon.com/KIB-LR9806-La.../dp/B009WQPL2U
If you want to make sure, take jumper from one side to the other on the relay. It supplies 12V to the panel.
My relay went out while we were out on the road. I took a battery jumper cable and clamped from one side to the other. I was able to make it home
and then got a new one. Pretty easy fix.
Joe & Kathy
2020: days camped 0
Old 12-09-2019, 09:29 AM   #11
Yes, this is in the electronics bay. My 12v panel is by the king bed.
just to verify.
Joe & Kathy
2020: days camped 0
Old 12-09-2019, 10:09 AM   #12
viperdave's Avatar
That certainly looks like it. I will definitely try and jumper it. Sometimes the obvious quick check is difficult to see! I will jumper and do a check then order the "latching relay". So nice to have a name to go with a part.
Thanks Joe for sharing your experience.
2016 Dynamax DX3
Old 12-09-2019, 10:20 AM   #13
That's why this forum is so great! Glad that I could help
Joe
Joe & Kathy
2020: days camped 0
Old 12-09-2019, 10:41 AM   #14
Dynamax Service Rep
I agree with the above replies,probably the latching solonoid,have someone push the aux start button on the dash and see if it supplies power to the other side of said solonoid
GTinsman is offline   Reply With Quote
Old 12-16-2019, 01:00 PM   #15
viperdave's Avatar
Got the new relay installed this morning and BAM, 12v power inside coach is restored. Thanks everyone!!!!
2016 Dynamax DX3
Old 12-16-2019, 06:23 PM   #16
Good deal!
Thanks for updating this thread and closing the loop for all of us following along.
2018 DX3 37BH
mookieblaylock is online now   Reply With Quote
dx3
