Lost all USB outlets in Isata5
I have lost all the usb outlets in my Isata 5. Checked the 15A fuse in the PP
Panel over door and found fuse blown. When replacing fuse takes new fuse out
immediately. To eliminate a bad usb plug disconnected all plugs in coach. Still takes out fuse. The incoming wires at the he plugs are yellow and white I’m figuring powers coming in on yellow. If I check both to ground they both have
continuity to ground and each other seems to indicate a dead short . Any
and all comments and suggestions appreciated on finding it or if I’m out in left
field its fine to say so. Thanks All
CNY Jim
2019
Isata 5 30 FW
