I have a 2016 DX3 36FK. I have lost power to my dash unit and have not been able to locate the fuse. I have found to different fuses under the hood labeled radio but both seem to be good. Does someone know of where any other fuses for this unit might be located ?
Check the fuse panel located in the Electrical bay, I am pretty sure that the fuse that supplies power to the radio relay in the dash comes from there. The relay in the dash is energized by the key on/acc signal. check that also.
Same thing happened to me and the in-line fuse to the unit was blown. Remove the dash trim and pull the radio out - you'll see the black fuse holder. However for me when I replaced the fuse it immediately blew again. I contacted the radio mfr (RiverPark) in Illinois and was happy to hear they would replace the radio under warranty which they did. Received the new unit and sent the old one back in the same shipping box. Hope this helps.
Don
RiverPark
Technical Support
1-800-442-7717 (U.S. Only)
574-522-7781 Ext.324
Fixed. Thanks everyone. Was a 10 amp fuse in the electrical compartment. The LED awning lights are on that fuse as well. Both work now.
Lots of good input.
