11-21-2017, 08:51 PM
M2-106 Electrical Problems
FYI: Intermittent problems with engine electrical, such as: engine continues to run with key off, brake lights, tail lights, ABS system, Parking brake and warning sirens, with numerous bulkhead module vaults.
There is a round 47 pin male/female connector located behind the left fender, between the fuel tank and the frame up by the dashboard firewall.
You can see it laying on the ground and looking up, but you can not get to it.
Connector had water, and was badly corroded, and shorted. They have no idea how water would get there.
Freightliner has to remove left fender to get to the connector. the connectors were replaced under warranty, and all is well.
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
11-21-2017, 09:47 PM
Must not have been connected tightly. Those plugs are pretty reliable. Isolated innocent I bet they told ya.. or, its the first they've seen.. glad it was found and corrected. Now I'll look around and check mine. Thanks for the heads up.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
11-21-2017, 10:09 PM
Isolated incident, but they have seen it before.
Not fun having that stuff come on while driving down step grade in West Virginia, like warning "parking brake on" with warning siren blaring.
Just thought I would give everybody a heads up.
Joe & Debbie
11-22-2017, 01:44 AM
Consumer of Space
Thanks for sharing, glad you got it taken care of.
2018 Dynamax Force HD 37BH
11-22-2017, 08:25 AM
Thanks for sharing, hopefully it was a one time thing for all of us.
Even though these are big trucks, it is funny how many things are in an area that you cannot reach without removing something.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
11-22-2017, 08:33 AM
Wrench Turnin Fool
I have to do this but, I have a bunch of those in my fleet and they are electrical nightmares.
I hope this is your only run in with freightliner's electrical Gremlins
Not all who wander are lost...
But I usually am
2001 Coleman SantaFe pop up
Excited new owner of 2018 Arctic Wolf 315TBH8
Towing with a 2005 F-250 5.4 GASSER
11-22-2017, 09:17 AM
Any recommendations or something that can be done to prevent? Would spraying a layer of urethane do the trick?
11-22-2017, 11:53 AM
On my Blue Bird Wanderlodge I would disconnect cannon plugs use dielectric grease and re-connect.
11-22-2017, 12:57 PM
Ugh
Kevin & Jean
2018 DX3 37BH
11-22-2017, 02:19 PM
Wrench Turnin Fool
That works... But it's not easy since they have a penchant for burying everything
But I usually am
11-22-2017, 03:05 PM
Yes, dielectric grease was used on the new plug. I asked for a picture of
the old plug, as soon as I get it, I will post picture of where this plug is
located. you can see it laying on the ground, I don't know if it can be
unplugged from the ground.
Joe & Debbie
11-22-2017, 05:29 PM
Here are the pictures of the old male/female 47 pin and the new, so when you are under looking up along side the drivers fuel tank and the frame,
behind the drivers front tire you can see the connector there. Don't think that you can reach it and unplug it. Maybe you can.
Joe & Debbie
