Went to Freightliner today. They did the inspection on the recall. Yep, I have one of the axles with the issue which is:
During assembly apparently some spacer washers were left out of the assembly. They go between the I-beam and the leaf spring mount pad.
The I-beam is not flat on the mounting side. There is supposed to be 3 washers on each of the U bolts to let the mount guides to center the axle on the spring pad. Mine had the 3 on the back side but none on the front side. The washers are of a specific thickness and inner/outer size. At least this is how I understand the issue. Of course none are in stock and had to be ordered.
The inspection took all of 30 minutes. 28 minutes of paperwork and the remainder to check it. Total of 12 washers needed.
Should be here in 2 weeks.
Then I can schedule the install.
another 240 miles round trip.
