Old 02-11-2019, 08:17 PM   #1
Motorhome bottom seal
I was under our 2019 Dynamax Isata 3 24 FW. Looking at the tank drain valves, I could see lots of wires and hoses going toward the kitchen area. I was thinking that some critter could live up there! How can I find out what is supposed to be sealed up and not missing some covers that should seal those areas? thanks in advance leonard
wanderer44 is offline   Reply With Quote
Old 02-16-2019, 09:23 AM   #2
shultz01's Avatar
If you store your unit outdoors like we do there's not much you can do to keep mice and such from "exploring" your chassis. There are products you can stray on the chassis or repellents you can put inside to deter critters.
All the holes made for hoses and wiring are sealed at the factory. All you need to do is make sure nothing was missed or foam didn't expand the way it was supposed to. The best thing to do is poke your head in all the cabinets and look for daylight. From the outside you can check inside and outside of all the compartments and the floor bottom to make sure you can't see light from inside or an obvious gap. If you see any openings that need sealed just use some expanding foam to seal them up.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
shultz01 is offline   Reply With Quote
motorhome, seal
