Old 05-16-2016, 03:56 PM   #11
AWF1945's Avatar
Haven't heard wether you found the problem yet. Still seems to me the 12 volt strip isn't getting power. Loose wire, ground?? thanks for the update..
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 05-16-2016, 09:04 PM   #12
Found the mystery fuse problem, After talking to the factory and them knowing less than me, Someone from the Dynamax board found a pictorial of that fuse strip, There are two feeds one for the bottom 5 one for the top 5, Now the bottom is a normal Red 12ga and bolted on like you would expectm BUT the top is powered by a 12ga red wire that is just a spade clip. seems as I closed the door to that section it bumped a waire that knocked the spade connector off, and it was hidden behind a cluster of wires,Pushed it back on and Presto 12v apears at ALL fuses, Thanks for all the replys, even when something cannot be figured out right away, knowing that there are folks out there who would try to help, Thanks again,.
Bill340 is offline   Reply With Quote
Old 05-16-2016, 09:43 PM   #13
VinceU's Avatar
By the looks of the lower solenoid that assembly may act as the battery isolator (for concurrent
Battery charging) and parallel starting circuit.
Old 05-16-2016, 09:48 PM   #14
AWF1945's Avatar
Thanks for the update Bill340. Glad it was a simple fix. I never thought it would have had two 12v feeds.. never know till ya take it apart.
Old 05-17-2016, 12:24 PM   #15
Head Rambler
Thanks for posting the resolution to the problem. I suspected that it had separate feeds to the top and bottom. That's why I asked if you checked it with the ignition on and off. From now on I'll know to suggest looking for a disconnected wire.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 05-17-2016, 07:16 PM   #16
Well - learned alot about that subject. Thanks for sharing. Mike
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
fuse
