Old 07-08-2019, 02:50 PM   #1
kaulick's Avatar
Nasty blowout of front driver side tire on our ISATA 5
Traveling on the I-40 westbound about 30 minutes out of Nashville, TN. Tire blew with incredible force blowing off the wheel well, the side step and part of the front lower plastic. Had a TST monitor but no prior warning of the blow out or any indications from the monitor that anything was wrong. Been sitting on the side of the road for over 3 hours waiting for a mobile tire repair. Click image for larger version
ID:	209351Click image for larger version
kaulick is offline   Reply With Quote
Old 07-08-2019, 02:58 PM   #2
Chuck_S's Avatar
Cold tire pressure that morning was per the placard on the door jam? Vehicle was not overloaded?
Other than road damage violent blowouts are caused by under pressure and overloading. Tires over 4 or 5 years old are too old.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 07-08-2019, 03:06 PM   #3
kaulick's Avatar
Tire pressure was at the right amount. Dynamax last year changed out my front axle putting a more heavier duty axle in since the built it over weight in the front. This is one of the first ISATA 5s to roll out. Tires have about 30k miles on them and are 3 years old from the time we received the unit.
Old 07-08-2019, 03:07 PM   #4
GM
bclemens's Avatar
Did you notice any temps rising? Looks like the tread came off completely.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-08-2019, 03:08 PM   #5
kaulick's Avatar
Didnít get any indicators on the TST unit. Have the temp set at the factory setting. Not sure if was a quick rise in temp and never registered.
Old 07-08-2019, 03:09 PM   #6
GM
bclemens's Avatar
As a side note, we didn't change the axles. The only difference between the 7,000 and 7,250 rating are the springs. We replace the existing springs with the HD spring as part of their HD package. Ram told us originally that the 4x4 came that way. We later found out we needed the HD option....which we also found out were springs. Supposedly they are changing the option name to reflect that.
Old 07-08-2019, 05:01 PM   #7
Bill Davis's Avatar
If itís a 2017 rv then is probably a 2016 Chassis so tires could have a date code as old as 2015. That and the mileage could have contributed to the blow out. My Isata 3rw is a 2017 with a 2016 chassis with 33000 miles and I just replaced the Continentals with Michelinís. It would be interesting to know the date code on your tires.
2017 Isata 3RW
Bill and Carol
Retired mechanic and shop owner
US Army Veteran 🇺🇸
Bill Davis is offline   Reply With Quote
Old 07-08-2019, 05:09 PM   #8
Chuck_S's Avatar
Maybe even older as 2016 chassis "model years" started in 2015 and the tires could easily been in the warehouse for a couple of years.
-- Chuck
Old 07-08-2019, 05:40 PM   #9
Bill Davis's Avatar
-- Chuck
Very possible.
2017 Isata 3RW
Bill and Carol
US Army Veteran 🇺🇸
Old 07-08-2019, 06:00 PM   #10
Rrzasa's Avatar
I had to replace the Conti HSR’s on the front after 35,000 miles. Had them inflated to 95 as per the door sticker and they wore out from under inflation. They are now at 105 and i’m told there is very little wear after 9,000 miles.
Tire shop owner told me that since the rig was running at the max on the axle limit that he was surprised that I only wore them out instead of blowing one out.
A little harsher ride but the airbags offset it so no biggie.
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Towing 2005 Honda Big Ruckus
Go Gators
Rrzasa is offline   Reply With Quote
Old 07-09-2019, 12:06 AM   #11
kaulick's Avatar
ID:	209423Click image for larger version
Old 07-09-2019, 08:51 AM   #12
kaulick's Avatar
The chassis is a 2015 even though the RV is a 2017. The tires had 29k on them.
Old 07-09-2019, 12:13 PM   #13
2014 XLR 27HFS
dave961's Avatar
I feel your pain.this happened to me Saturday driving home. Took the wheel well trim out and ripped off the black tank flush connection. Also cut the tire next to it. Good times.
dave961 is offline   Reply With Quote
Old 07-09-2019, 05:30 PM   #14
kaulick's Avatar
Wow, that looks worse than mine. I am lucky that we didnít rupture the front fuel tank that sits next to the rail.
Waited 5 hours for mobile tire service to arrive. Luckily enough fuel to run the generator so we had AC during the wait.
Old 07-10-2019, 10:39 AM   #15
kaulick's Avatar
Thank you Brian. Thinking of going with the one comment and pumping the front tires to 105. What do you think? I keep them know at the 95.
Old 07-10-2019, 10:47 AM   #16
Date code
Every tire manufactured has date code stamped on it. Would be interesting to know that if you still have the carcass.
pkmkaz is offline   Reply With Quote
Old 07-10-2019, 10:57 AM   #17
GM
bclemens's Avatar
I’m certainly not jumping into the tire pressure debate, those get really long. Cold tire pressure should be based off of a scaled weight load. We run them all at max pressure from the factory as required for not knowing your loaded weight. if you leave them there it will likely be a harsher ride if you are carrying a lighter load.
Old 07-10-2019, 11:18 AM   #18
Chuck_S's Avatar
I'd have this ""rig" weighed and see if or how much over gross weights (axles and gross) it is.
Tires are seldom the governing factor in the suspension rating and frequently have capacities well in excess of the suspension (axles and springs) -- but they gotta be properly inflated to support the actual weight which ya don't know without a scale. I think it's under $20 at a CAT scale and takes 3 minutes. Ask one of the hot shot truckers weighing their pickups and trailers for help. Most seem more than willing.
-- Chuck
-- Chuck
Old 07-10-2019, 11:36 AM   #19
-- Chuck
-- Chuck
I'm cheap. I weigh my truck/trailer at the nearby state Weigh Station that is unmanned most of the time but the scale readout is visible through the window in the door. It's 2 miles from my house on a secondary highway.
Free is a great price
FWIW, most of the scales on the Interstates in our state have weight readouts on poles where truck drivers can see as they drive over. When the scales are closed and unmanned just drive your rig across and weigh for free.
Naturally this will vary by state but it's one thing we do benefit from here in WA.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-10-2019, 12:03 PM   #20
Bill Davis's Avatar
It is nice to know your front and rear axle weights so you can adjust your tire pressure for best ride, fuel mileage, and safety. I donít know what brand of tire you purchased but I have Michelin and they have a chart on line for psi by axel weight. My Isata 3RW has a front axel weight of 3900# and a rear weight of 1160#. That allows me to run my tire pressure as low as 55#. I run them at 60 to be on the safe side. I use the cat scale, it was only $11.00 and they guarantee accuracy.
FYI I weighed it packed and ready to travel with me in the drivers seat, full of fuel and 1/3 full of fresh water. Gray and black tanks empty.
2017 Isata 3RW
Bill and Carol
US Army Veteran 🇺🇸
tire
