Old 06-08-2018, 05:36 PM   #1
caseymyers's Avatar
Need 20 AMP 12 VDC Circuit Breaker
Does anyone have a wiring diagram of an ISATA 5 DS? I want to install a power cord reel and I need a 12 VDC power source protected by a 20 Amp circuit breaker.
Are there spaces to add extra breakers in the box? And where can I buy breakers?
Thanks,
Casey
Old Navy Chief
2019 Isata 5 36' DS 4x4
2015 Jeep Rubicon Toad
Days camped 2021 = 25
caseymyers is offline   Reply With Quote
Old 06-08-2018, 06:53 PM   #2
Just as confused as you
Scrapper's Avatar
Are you talking about a 12vdc motorized power cord reel? Any empty spaces in your power center will be for 120vac breakers or 12vdc fuses. If it is a motorized power cord reel then you will most likely have to install a mini fuse, resettable fuse or an auto-reset fuse inline with the 12vdc positive wire to the motorized cord reel.
Richard & Jill
Old 06-08-2018, 06:58 PM   #3
Name:	What he said in that comment up there (1).jpg
Old 06-08-2018, 07:04 PM   #4
Thanks,
Casey
Auto parts store.
Old 06-08-2018, 09:19 PM   #5
caseymyers's Avatar
Thanks. I can buy all this at an auto parts store?
Old Navy Chief
Old 06-08-2018, 11:01 PM   #6
One of the three. Your choice.
Old 06-09-2018, 11:46 AM   #7
Talking
Plastic encased - auto reset
The metal encased type are a bit more risky. If they were to come apart, the internal conductors could make contact with the casing which is typically mounted to a grounded surface.
Magnatudes is offline   Reply With Quote
Old 06-09-2018, 01:41 PM   #8
RKBob's Avatar
12vdc circuit breakers are available at most marine supply stores. I was looking at that for mine (eventually) but there’s no place to instal on the left side so l thought I should get a few hookups and see how much cable I would need. The best reel I’ve located is a Glendinning but the cable is only 36 ft in the rv reel type. With 8ftof beam and 2-3 ft vertical drop there’s only about 25 ft reach an I don’t know what to expect in most camp grounds.😎
2019 Dx3 TS
2020 RAM 1500 Limited Diesel 4x4
7 lb Guard Dog
Working hard on “elderhood”
RKBob is offline   Reply With Quote
Old 06-09-2018, 01:49 PM   #9
RKBob's Avatar
Oh yeah Casey, run a 30 amp fused (2ft prox) from the source to a box with said breaker in the reel compartment.😎
2019 Dx3 TS
7 lb Guard Dog
Old 06-09-2018, 02:12 PM   #10
DouglasReid's Avatar
depending on where your converter/load center is located you may want to run a separate wire direct from your battery, for ease of installation. In that cse you will need an inline fuse holder similar to this:
https://www.walmart.com/ip/Seachoice...&wl13=&veh=sem
You should mount it as close to the battery as possible to protect the entire length of wire from the battery to wherever you need i to go for the reel.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-10-2018, 09:10 PM   #11
caseymyers's Avatar
https://www.rvupgradestore.com/Motor...p/cr12d-sr.htm
Old Navy Chief
Old 06-10-2018, 09:12 PM   #12
caseymyers's Avatar
RK Bob
Try this one. Less than $200 and it's for the detachable cords like the 50amp in the Isata 5. I just got it a couple days ago and have yet to install it. Seems like it should do the job.
Old Navy Chief
Old 06-11-2018, 07:42 AM   #13
RKBob's Avatar
So you take the compleat original cord off to hook it up and then replace it and wind it back it on for storage? It looks like it might be a viable option. If you do the instal let me know how it works out. It looks like my delivery has slipped a bit but the closer it gets the higher the excitement factor!��
2019 Dx3 TS
7 lb Guard Dog
Old 06-11-2018, 08:56 AM   #14
caseymyers's Avatar
You could hard wire a cord too, and it would have to be attached on the utility bay side, but you don't have room on the drivers side to install the reel, at least I don't, plus hard wiring the shore power cable is over my pay grade. And the hard wired reels are about $400. Scott put in a Morryde hand crank reel and he likes it, this is very similar, just no hand cranking. I had them on a couple of busses I had and they are very nice, and really help in the utility hook up department.
Old Navy Chief
Old 06-13-2018, 08:47 AM   #15
caseymyers's Avatar
Wiring my Power Cord powered reel.
Originally Posted by cavie View Post
Auto parts store.
So now that I have parts. So take a Red wire from the positive side of the battery post (the post where the solar feeds in?) run a short piece and put an inline fuse (20amp) to protect the wire in case it gets frayed. Run that red wire over to the storage bay where I have my Reel installed. Mount the 20amp circuit breaker on the bulk head near the reel. Attach the battery red wire to one side. The red wire from the switch to the other side. Run the black wire to one of the mounting bolts for the plastic cargo bay (they'd be screwed into the frame?) and it should work?
What size wire for the long run, 10ga? 12ga? multi strand automotive I presume?
Advice?
Old Navy Chief
Old 06-13-2018, 09:29 AM   #16
RKBob's Avatar
I would run a 10ga duplex with 30amp on hot and a dedicated ground. The 20 amp breaker sounds good. 😎
2019 Dx3 TS
7 lb Guard Dog
Old 06-13-2018, 09:36 AM   #17
caseymyers's Avatar
What is a 10ga duplex?
You mean a 30amp fuse?
Dedicated ground is a black wire to the frame?
Thanks for the help.
Old Navy Chief
Old 06-13-2018, 09:46 AM   #18
Marine Wire AWG Gauge Size Flat Duplex 2 Conductor Boat Cable Genuinedealz.com
babock is offline   Reply With Quote
Old 06-13-2018, 09:56 AM   #19
caseymyers's Avatar
Why this kind of wire? You are recommending that the ground go all the way to the battery? Why? Just trying to learn.
Old Navy Chief
Old 06-13-2018, 12:00 PM   #20
RKBob's Avatar
Duplex is 2 conductors in one cable. I just assumed the wire would run out side of the cabin and you would use UF cable. A30amp fuse is appropriate for a 10gage conductor. The “upstream” fuse protects the wire and the 20amp breaker protects the load and acts as a disconnect. Grounding at the battery screw terminal is much less likely to develop corrosion and subsequent poor grounding. The ground is also carrying current. That’s just the way I would do it (probably will). Either way let me know how it works out in actual use😎
2019 Dx3 TS
7 lb Guard Dog
breaker
